Old 02-17-2016, 10:06 AM   #1
tnbendr's Avatar
Cost of oil change
I know we've talked about oil changes and the cost, but the "search this thread" feature is not working. I'm staying at The Great Outdoors in Titusville FL and they have an on site facility that quoted me $289 to do oil, filter, chassis lube and check all fluid levels. This is my first time, seams a little high or is this reasonable?
Ben & Michelle
2015 Berkshire 38A
2005 Jeep Wrangler toad
tnbendr is offline   Reply With Quote
Old 02-17-2016, 10:39 AM   #2
If that's for the main engine as well as generator it's a pretty decent price. If it's just for the main engine oil change, it looks a little high to me.
Gotta go campin!
Old 02-17-2016, 10:56 AM   #3
gasman94's Avatar
I got 37 point preventative maintenance check, oil change, lube, fuel filter, water separator, coolant test w/strips and a gallon of washer fluid for $214.81 at my local freightliner oasis dealer. My first oil change was done through a dealer and it was about $225 and took about 4 hours. They overfilled and did tell me that they didn't do many diesels. I never went there again for an oil change. I have done it myself for about $75 for oil and filter. Not hard to do, but must have tools, place and something to catch the oil.
Rich
gasman94 is offline   Reply With Quote
Old 02-17-2016, 12:29 PM   #4
silver's Avatar
You said it is on site so I take they are coming to you. On top of that until you have crawled under a Berk to lube it you have no idea what fun is, I would say that is not bad.
silver is offline   Reply With Quote
Old 02-17-2016, 01:22 PM   #5
Berkshire 390QS
NO3putt's Avatar
Our local cummins/freightliner dealer charges $480 that includes all filters, gas and oil, chassis lube, complete chassis/engine inspection and radator anti-freeze testing. That includes the generator and engine.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
Old 02-17-2016, 03:45 PM   #6
tnbendr's Avatar
Thank you all, that gives me a better idea
Ben & Michelle
2015 Berkshire 38A
Old 02-18-2016, 12:59 PM   #7
aerohead34's Avatar
Well hello neighbor! We are staying at the Titusville KOA about 9 miles up the 95.
2013 Cherokee 284BH
2017 RAM 3500HD Laramie, Mega Cab, 4X4
aerohead34 is offline   Reply With Quote
Old 02-18-2016, 02:07 PM   #8
tnbendr's Avatar
Greetings, are you attending Daytona?
Ben & Michelle
2015 Berkshire 38A
Old 02-18-2016, 03:33 PM   #9
aerohead34's Avatar
I am down here for a six month contract job. We probably wont be doing Daytona
2013 Cherokee 284BH
Old 02-18-2016, 03:37 PM   #10
fedexflyer's Avatar
If you're heading west they have Speedco service centers for large trucks and RVs. I got the full Monty done in Vegas for $166. Next time it's due I'm heading out west again, it's just too good of a deal. Not sure their range of operations but great service.
USCG Ret
2020 Winnebago Vita 24F
2018 Jeep Wrangler Unlimited Rubicon Recon
fedexflyer is offline   Reply With Quote
Old 02-18-2016, 06:52 PM   #11
Can not really judge price as you did not (do not?) have the brand/ type of oil, oil filter, if the generator is being serviced?
You will find that the price of this is going to change all over the country, but to service a big diesel is NOT cheap,(people need to understand this is not your fathers chev, anymore) there is a lot of oil, the filters (yes more than one) are not cheap for approved filters and YES there is a huge difference from good to cheap filters in the media filtering abilities. So if they are using good quality oil and filter it is not to far out or range, but as i stated you do not have all the info to really give a good opinion.
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 02-18-2016, 07:44 PM   #12
AquaMan's Avatar
For the prices mentioned, I would be doing my own service work.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 02-19-2016, 12:02 AM   #13
dan-nickie's Avatar
Did you know there are at least 3 Speedco locations in your state?
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 02-19-2016, 08:49 AM   #14
I-RV's Avatar
I doubt that anyone can do the annual service recommended by Freightliner for $166. Probably can do only an oil change for that price.
A typical annual service for a Berkshire as recommended by Freightliner is shown below.
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 02-19-2016, 08:58 AM   #15
AquaMan's Avatar
Hank
Do you do this annually? It says 36 month service.
Old 02-19-2016, 12:48 PM   #16
tnbendr's Avatar
This is only engine oil change, including chassis lube and checking all other fluids. The oil they are using is Shell Rotella T 15w40 and filter is Lubrifinder. Don't know if I spelled them correctly but are those ok?
Ben & Michelle
2015 Berkshire 38A
Old 02-19-2016, 01:11 PM   #17
2014 360 QL
po 185's Avatar
that is what I use
2014 360 ql
po 185 is offline   Reply With Quote
Old 02-19-2016, 08:49 PM   #18
tnbendr's Avatar
Dan, I looked up the nearest Speedco and the view on Google maps looked like a dump, also all reviews were very negative. Don't want to take it there!
Ben & Michelle
2015 Berkshire 38A
Old 02-19-2016, 09:04 PM   #19
Do motorhomes even need chassis lube? Most cars and trucks these days have "permanently" lubed joints - but maybe I'm just ignorant about MH's.
Almost sounds like a gimmick. I know auto repair shops still push "tuneups" to the ignorant, even though new cars don't have points, condensers, distributor caps or most of the other stuff you replaced or adjusted during a "tuneup."
2011 Traverse LT, 3.6L, FWD
Old 02-19-2016, 09:38 PM   #20
Campin Cajun's Avatar
That 36 month schedule means when the coach is 36 month old. Not to do the maintenance every 36 months.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
