Old 11-17-2014, 01:59 PM   #1
Cost of service
I owned a twin disel powered boat for years (Volvo D-6's) and did all my own maintenance, fuel filters, oil filters, air , coolant, etc. When I suggested to DW that the motorhome should be easy in comparison (no impellers to change, no zincs, and much easier access) she said let the local Cummins people take care of it. They quoted me $284.00 for the gen set and over $400 for the engine ,an ISB 6.7 360. The genset included the air filter and the engine service included checking coolant , serpentine belt, etc. Do these figures seem high to anyone but me? What do you pay for service?
Dan
2015 Entegra Anthem 450HP-1250ft lbs of torque
2015 Jeep Grand Cherokee
Roadmaster Falcon 2 All Terrain
SMI Air Force 1
seeg is offline   Reply With Quote
Old 11-17-2014, 02:34 PM   #2
Berkshire 390QS
NO3putt's Avatar
Dan,
A bit high compared to what we pay, oil, chassis lub, all filters, (oil and gas) inspection of entire chassis around $500 for both engine and generator at our local FL/Cummins dealer.
We budget $1,000 each fall for our yearly preventative maintenance, air filter some years, air dryer others, there is always something beside the oil change each year.
Skip
NO3putt is online now   Reply With Quote
Old 11-17-2014, 02:54 PM   #3
silver's Avatar
After going to camp freight-liner I do it myself. Spend less than $100 per year and I know what has been done. As you stated it is not hard. The money I save goes for diesel.
silver is offline   Reply With Quote
Old 11-17-2014, 03:06 PM   #4
JTN8's Avatar
Sounds high to me too, I do the generator myself for maybe $40 ish.... I take it to my local FL service center for the chassis lube and all the oil and fuel filters and it was around $375ish I believe.... Gen set is very very easy!
Jason
Old 11-17-2014, 06:06 PM   #5
Called FL and they'll do everything including the chassis lube for $400-$500. Sounds better. I had the DW talked into doing it ourselves this weekend but with temps in the teens I'd rather let them do it than freeze doing it myself. And, I probably would have taken it to FL for the chassis work anyway. Apparently they have some sort of package pricing for lube , oil and filter changes as their hourly rate is $189.00. I'll have to raise my hourly rate to keep up.
Thanks for your replys.
Dan
SMI Air Force 1
Old 11-17-2014, 09:57 PM   #6
Gottawonder's Avatar
$189, because $200 would seem unreasonable
Gottawonder
2014 Berkshire 390RB-60
2014 Jeep Wrangler Unlimited
Roadmaster Falcon A/T tow bar
Gottawonder is offline   Reply With Quote
Old 11-18-2014, 08:12 AM   #7
glevron's Avatar
Just had mine service @ Kent Mitchell oasis dealer in hammond, La One yr service, 6k miles. Oil & filter change, fuel filters changed, transmission filter changed & chassis lube. $332 Did generator myself!
glevron is offline   Reply With Quote
Old 11-18-2014, 06:36 PM   #8
Campin Cajun's Avatar
Not a bad price for all that.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 11-18-2014, 07:13 PM   #9
gasman94's Avatar
FL Oasis dealer in Mattawan, Mi. 37 point inspection, lube, fuel filter, water separator, coolant test, washer fluid ad 16 oz. bio kleen power service fluid (16) oz.......$189
I did my own oil change and gen oil change.
Rich
gasman94 is offline   Reply With Quote
Old 11-20-2014, 07:26 AM   #10
I-RV's Avatar
I applaud all those doing there own maintenance. I hate to say what I paid at the Freightliner Oasis in Gaffney with seeing all of your low dollar figures. I paid for 5 hrs. of service. They got me on a $163 air dryer kit and $80 air filter. This was my 24 month maintenance.
I am wondering however if everyone is following the Freightliner maintenance schedules. I have attached two schedules. I for one do not understand Freightliner calling for changing the power steering fluid, its fluid and rear axle fluid every 12 months. Also the tranny filter for the 2500MH, every other year.
Some of this appears to be excess, but I wasn't about to argue, considering my investment.
I-RV is offline   Reply With Quote
service
