Old 05-21-2012, 09:02 AM   #1
Cracked water fitting
I had a plastic fitting crack over the winter right at the joint with a line. It looks easy to replace, but for the life of me, I can't find the part. The pic is attached. Does anyone know what this type of plumbing is called and what the standard size on a 2011 BH is. This is the FIRST thing I've encountered that I haven't been able to solve myself and we're going away for memorial day. Thanks for any help.
http://www.forestriverforums.com/for...1&d=1337608783
Name:	Water valve.jpg
brevin66 is offline   Reply With Quote
Old 05-21-2012, 09:35 AM   #2
Just changed some of those in my rig don't know what the plumbing is called but believe it or not ace hardware had all of those fittings big box store didn't have any, you might check ace if you have one close by
jalvin is offline   Reply With Quote
Old 05-27-2012, 09:58 AM   #3
VinceU's Avatar
The pipe system is made from Pex tubing and fittings. Fittings can be metallic, or hard plastic as you have, screwed or compression attached. Very popular in the fab housing ind. Large hardware stores carry it (call). Super multiple stores limited in fittings.
