08-25-2015, 01:16 PM
Crappy shower valve replaced
Just replaced the cheap shower valve and control in our new Berk. We have an Atwood tankless and found it a pain to adjust the temp while in the shower. Purchased a Delta Lahara Pressure Balance valve and now the temp problem is completely solved.
I would suggest this to anybody who has the same issue with adjustment during their showers.
2015 Berkshire XL 40BH
Toad 2015 Chevy Equinox LTZ V6
08-25-2015, 01:56 PM
Boxers,
Where did you purchase this and what did you need to purchase? I see that there are references to a valve, is that something that needs to be replaced also? What did you pay?
Tom and Margaret
2014 Berkshire 390bh-60
08-25-2015, 02:01 PM
Any information will be helpful!
Paul
08-25-2015, 02:24 PM
We have same issue on our 2016 38a. Love the Atwood tankless on all other faucets but shower is a pain to adjust. Any product number and pictures and "how to's" would be greatly appreciated as we'd love to fix our issue as well!
Thanks!
--Nathan
2016 38a
--Nathan
2016 38a
08-25-2015, 03:06 PM
Great!! Thanks for the info!
Tom and Margaret
08-25-2015, 03:11 PM
tmmar, let me know how you make out with the conversion. Does your unit have the Atwood tankless and do you have the same temperature control issue?
08-25-2015, 03:23 PM
Boxers-rule
Does the control you installed have independent flow control and hot/cold mixing control? I have a house shower control that is always full flow and allows mixing hot and cold.
2012 Berkshire 390BH
Gale & Hank- 2012 Berkshire 390BH
My coach has the Girard heater. Have some minor issues with temperature control but looking to eliminate them completely.
Tom and Margaret
08-25-2015, 09:24 PM
Yep, two levers. One flow and one mixing.
08-25-2015, 09:46 PM
Did you replace the shower head also?
Any feedback on that if you did?
Dan
2014 Berkshire 390RB-60
08-26-2015, 07:45 AM
Is the mixing lever for when you have a tub spout and shower head? How does that work when you only have shower head?
Wayne
Wayne
08-26-2015, 09:16 AM
Dan,
Which shower head do you have? I replaced my with an Oxygenics and it really make a difference with the water pressure coming out of the head. Much better.
Tom
Tom and Margaret
08-26-2015, 09:24 AM
Originally Posted by tmmar
Dan,
Tom
We are using the stock head that came in out 2014.
We had an Oxygenics in the last rig and am familiar with it. I actually have a new one in the closet I was going to put on while dry camping at Nascar races to save on water.
We are not unhappy with the stock head.
I just wondered about the one shown in the link as it shows a 'fixed' shower head without a hose,
Dan
08-26-2015, 10:01 AM
Didn't replace the shower head but one could as easily as in your house. One did come with the trim kit I bought, I just didn't think it necessary to change it.
08-26-2015, 10:03 AM
The mixing lever would control any water coming from the valve, including a tub spout if you had one.
08-26-2015, 10:10 AM
08-26-2015, 10:14 AM
Gasman94,
The link you sent over isn't for a pressure balance valve. There is no mixing lever so unless you wish to just change the trim kit without the ability to adjust the temp as I have indicated, you should look for another kit. I believe the Lahara I purchased does also come in the Venetian Bronze though.
08-26-2015, 10:20 AM
To all that have responded,
I don't want to suggest that my solution will solve all your problems. I believe the worst problem I had was the hard time we had adjusting the mix between hot and cold with the crappy valve and trim kit supplied by Forest River.
A pressure balance valve with the mixing lever DOES solve issues of hard to adjust shower valve handles, along with the fact that any faucet turned on in the motorhome during your shower will not affect the temperature during your shower. It's main feature is that it counters any drop in pressure from either side (hot or cold).
Very simple really.
08-26-2015, 10:24 AM
Another note on the shower head, I was not able to find a Delta trim kit (pressure balance) without a shower head included. I seem to remember at one point prior to the switch that some internet site had a full kit without the shower head but including the needed pressure balance valve. Never could find the website again when I went to purchase so I ended up at Home Depot online.
