Old 10-17-2015, 05:19 PM   #11
dan-nickie's Avatar
Originally Posted by 5456Mich View Post
Also noticed about a 2 1/2" hole in the basement ceiling that I'm thinking maybe for heat. Anyone notice that before ?
Pictures of the hole?
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 10-17-2015, 05:34 PM   #12
I have the same thing. It's like they drilled in the wrong place.
Old 10-17-2015, 05:40 PM   #13
Dan I can get a picture tomorrow but it's on the passenger side of coach in the section that has the smaller of the basement doors towards the rear.
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 10-17-2015, 05:44 PM   #14
Why do you say that Phil ? I didn't turn the heat on and see if any came out, just figured that was near a chase of some sort. Must be harder to heat under there if all them spaces around the frame rails are left open.
Hey ! Who needs heat when they're in Florida ? lol
Joe & Lori
Old 10-18-2015, 10:12 AM   #15
Dan it's between the frame rails.
Joe & Lori
Old 10-18-2015, 12:14 PM   #16
dan-nickie's Avatar
Attachment 92031
I see. I've crawled around in there and never noticed 1 in my 2014 390RB.
Dan
Old 10-20-2015, 03:49 PM   #17
Attachment 92031
So I turned on the heat today and then got in the basement and sure enough heat was a blowing out of this hole. With all the gaps around the frame rails I had the heat was just going outdoors. Had significant heat blowing out , I'm thinking of trying to find a register that will fit the hole so that it can be adjusted if need be. By closing this down some you'd get more heat above in the living room. Just a thought.
Joe & Lori
Old 10-20-2015, 04:11 PM   #18
15berkxl's Avatar
Joe not necessarily restricting air flow can hurt efficiency since the furnace is sized to move so much air and upper limit can trip shutting off warm air to where you want it.
I guess if it ain't broke don't fix it.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 10-20-2015, 04:14 PM   #19
15berkxl's Avatar
Also some heat had to go into the basement compartments to keep plumbing from freezing you may have done yourself more harm than good be closing off those areas.
Wayne
Wayne
Old 10-20-2015, 04:42 PM   #20
Wayne
Well haven't done anything yet. Doesn't seem to be any plumbing in this section of the basement. Not sure that I would close it off, just adjust it some. With all the areas that I closed up down there seems like it would be fine with less heat, but I agree it would have to be monitored.
Heck I'm not going anywhere this winter just making conversation.
Joe & Lori
