Old 09-11-2014, 11:14 PM   #11
Terrilegacy's Avatar
Are you holding the switch down while it rolls out. If so once it gets to the end it starts to roll back it. Just hit the out position once and see if that helps
Terrilegacy is offline   Reply With Quote
Old 09-12-2014, 01:02 AM   #12
dan-nickie's Avatar
Took me a little bit to get used to the "press and release" operation on my Berkshire awning also.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 09-12-2014, 02:30 PM   #13
[QUOTE=silver;698350]
Originally Posted by boowho View Post
OK, my Carefree main awning rolls out and then immediately rolls itself back up even though there is no wind at all. I've turned off the main power switch to the thing, but of course if the wind come up suddenly, I'm screwed.
Hi Boo,
While you have turned off the power switch the circuit is probably still energized. In the event the brain is confused you might want to turn off the coach batteries and unplug shore power for 5 minutes. Hard reset. see if this helps. Just an idea.
Thanks for all the ideas, people..... I'm surprised I'm the only one having this problem!!
Boowho??
boowho is offline   Reply With Quote
Old 09-12-2014, 09:19 PM   #14
[QUOTE=boowho;700035]
Boowho??
Someone has to be the first. Let us know how you fix it.
