Old 03-10-2015, 09:49 AM   #1
edgewant's Avatar
Dash Insulation
Any Berkshire owners out there that have insulated their dash on the generator side? If so what did you use?
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 03-10-2015, 12:36 PM   #2
gspencer4's Avatar
You didn't say whether you were fixing or trying to prevent a problem.
I haven't insulated but it is probably a good idea to do. Last summer I was driving running the gen for A/C and keeping the food frozen. My console components must have overheated because I had no cameras or radio/clock in the Jensen unit.
Greg Spencer
2014 Berkshire 390BH-60
"Scout"
Greg Spencer
"Scout"
Toad: 2014 Subaru WRX
gspencer4 is offline   Reply With Quote
Old 03-10-2015, 02:02 PM   #3
edgewant's Avatar
Its very noticeable when camping in either hot or cold weather. Just think it would make the coach more comfortable in those situations.
edgewant
Old 03-10-2015, 03:23 PM   #4
klucas's Avatar
Great idea. I also noticed a lot drafts at the stair well. I was wondering if there is a way to insulate that. Maybe some foam board attached underneath.
klucas is offline   Reply With Quote
Old 07-03-2015, 09:56 AM   #5
edgewant's Avatar
Anyone done the spray foam insulation?
edgewant
Old 11-26-2015, 10:22 AM   #6
edgewant's Avatar
Rode with a friend to Red Bay Alabama to have his 2009 Tiffin Alegro RED worked on. He was having some repairs made to the door latch. Did a self guided tour of the plant and noticed Tiffin insulates the firewall with a double-sided foil insulation that is only about 3/16 in thick. They also sell it at there on-site parts store. Claims are that it was used in the space shuttle and it has an R21 rating. Picked up 24 sq ft for $7.05. Plan to insulate the firewall, dash and step well. Will use spray adhesive that is resistant to heat and mositure. Will update this post with pics once I've completed the install.
edgewant
Old 11-26-2015, 10:33 AM   #7
Campin Cajun's Avatar
Not me but I would be interested in the results you get from doing yours. The only time I really noticed the lack of insulation was the day I was bringing the coach for service. It was about 45 degrees and raining. As I was driving the dash heater could not keep up with the cold air coming in through the dash area.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 11-28-2015, 08:53 AM   #8
jmgllt's Avatar
Following
jmgllt is offline   Reply With Quote
Old 11-30-2015, 11:25 AM   #9
ceedog's Avatar
Having drilled through the firewall, I've found that there is 1' foam insulation sandwiched between an outer steel plate (3/16' thick) & inner steel plate of the same thickness.
I couldn't find any opening to fish wire through for added accessories.
Never thought about adding additional insulation as me & the wife are comfy the way it is.
It ain't easy being me...I've tried.
ceedog is offline   Reply With Quote
Old 11-30-2015, 01:55 PM   #10
BamaBob's Avatar
Awesome (And Red Bay is not that far from Huntsville ) Yet another Mod I need to plan to do! Looking forward tot he picts Edge!
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
insulation
