Originally Posted by ceedog
I had the exact opposite on my 2011. Turned to be the control module for the chassis HVAC.
I appear to be having the same problem. No matter what I set the selector on, the air comes out of the defroster vent. Even in a/c mode, all the cold air goes out the defrost vents. It appears to be a vacuum leak or a control module, but where do you start? There are a lot of vacuum tubes under the dash.
BTW, Ford says it is a coach problem.
