Old 01-27-2016, 06:51 PM   #1
De-winterizing Berkshire 34QS
We are attempting to de-winterize our 34QS. It has a tankless hot water heater. We have cold water but no hot. Is there a bypass valve somewhere? If so, where?
mstoler149 is offline   Reply With Quote
Old 01-27-2016, 07:30 PM   #2
Campin Cajun's Avatar
First welcome to the forum. No there is no bypass valve on the tankless system. Which brand tankless do you have?
If Gerard II, make sure the switch on the unit itself is on and make sure your propane valve on the tank is open.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 01-27-2016, 07:49 PM   #3
dan-nickie's Avatar
Although probably not the issue, check that the valves in the water manifold are all turned on also.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 01-27-2016, 08:37 PM   #4
It is an Atwood heater. And, where and what is the water manifold?"
Old 01-27-2016, 09:02 PM   #5
We have the 34 QS as well. How do u like yours?
zimmnc is offline   Reply With Quote
Old 01-27-2016, 09:03 PM   #6
We were told for the Atwood to work right it is a matter of water flow. Minimum of a gallon and
Old 01-28-2016, 07:14 AM   #7
dan-nickie's Avatar
In the bay that you hook up your water, there are a number of valves that feed the coach systems. There is a cold and hot water valve for each sink, shower, etc.
Dan
Old 01-28-2016, 07:41 AM   #8
Problem solved!!! Thank you. It was a valve we had overlooked .
Old 01-28-2016, 07:54 AM   #9
I'm glad it was an easy fix.
Old 01-28-2016, 08:12 AM   #10
We love our 34 QS. It is truly a home on wheels. In the beginning we had some problems but everything was taken care of by Mitch Wirt. He's a true professional dedicated to making sure Forest River owners are satisfied with a great product.
berkshire, winter, winterize
