Old 03-24-2012, 11:04 AM   #1
de-winterizing the icemaker
I need to know how to de-winterize my Icemaker. I completed the de-winterization of everything else in my motorcoach, but I don't have any idea as to how to deal with the icemaker. Please help.
hark582 is offline   Reply With Quote
Old 03-24-2012, 12:15 PM   #2
sherdep's Avatar
How about year and model of your Berkshire for better results
does it make ice or no water going into the icemaker?
not sure if this is the case or not but I know when my parents had there motor home there was a valve that kept the water from going into the icemaker - my guess is the valve is in a "bypass" state
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 03-24-2012, 01:37 PM   #3
VinceU's Avatar
Ice Maker
Hark,
Not sure model you have, mine is Dometic 1350 in a FR 378 4 door refrig.
Restarted mine last weekend, supplied 110 VAC and water pressure (pump). Put bar down in cuber and when fridge got cold had my first harvest of ice. Took about 3 hours. Make sure all tubing is made up and no leakes present. Make sure both ac plugs in back are in.
VinceU is online now   Reply With Quote
Old 03-24-2012, 01:43 PM   #4
kingwood390bh's Avatar
I didn't use my ice maker on my last trip for that very reason. My guess would be to clean the house water system and run a couple of cycles of ice before injesting. That should get the fresh water into the ice maker
kingwood390bh is offline   Reply With Quote
Old 03-24-2012, 04:45 PM   #5
2011 Berkshire 390BH
Superchief's Avatar
I don't know your model, but I have a 2011 Berkshire 390BH. I was told when I de-winterize my unit to drain all of the antifreeze out first from the main water system, then drain the antifreeze out of the ice cube system. When my unit was winterized, they disconnected the ice maker tube to prevent the RV antifreeze from going into the unit and making pink ice cubes.
I have circled the tube with the pink antifreeze in it. I have also circled the part with the hose disconnected.
Also when they winterized it, they unplugged the electrical connection to the unit with the hose that was disconnected. I was told to drain this unit using a patch cord with two connectors that needs to be plugged into the area at the top of the next picture which is also circled. (you would need to unplug the existing connections there to drain the tube).
After you drain the hose, you would reconnect the disconnected tube to the unit. I hope this helps.
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
