Old 08-03-2016, 01:10 PM   #1
tmmar's Avatar
Dexron III
Was checking my hydraulic slide resevior and it says to use dexron II or III. I can only find dexron vi. Does anyone know if dexron VI is backward compatible with dexron II or III?
Tom and Margaret
2014 Berkshire 390bh-60
Old 08-03-2016, 01:21 PM   #2
Mmnsc's Avatar
Tom
Put in Marvel Mystery Oil. That is what Equalizer told me to use.
Mmnsc is offline   Reply With Quote
Old 08-03-2016, 08:06 PM   #3
Dex Vl is the synthetic version of lll. its a up graded version, your fine
Mike60 is offline   Reply With Quote
Old 08-04-2016, 09:29 AM   #4
tmmar's Avatar
Thanks guys. I went to a local auto parts store (Advance didn't carry the Dexron II) and they had it there.
Marty, didn't see your post until after I returned and put the fluid into the reservoir or I would have gone that route.
Tom and Margaret
Old 08-07-2016, 03:57 PM   #5
Go Seahawks!
Subsailor's Avatar
I am in the process of buying some Marvel Mystery Oil to top off my hydraulic reservoir. There seems to be more than one type available. There is a MM13R and an MM14R (that are different size containers), am I missing something here? Is all the Marvel Mystery Oil the same and I can mix it right with what is in the tank now? -Glenn
Glenn and Darcy
2013 Berkshire 390RB
2013 Jeep Wrangler (toad)
Pacific Northwest
Subsailor is offline   Reply With Quote
Old 08-07-2016, 06:56 PM   #6
Mmnsc's Avatar
The Marvel Mystery Oil I used was in a black and red rectangular quart screw top can. You can mix it with the oil that is already in the system. I took out about 1 quart of the existing oil and replaced it with the MMO.
Old 08-07-2016, 07:07 PM   #7
Iwannacamp's Avatar
I don't have a dog in the topic, but marvel is very thin compared to transmission fluid. I seem to remember trans fluid is about 20WT.
My only advise is to be careful.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 08-07-2016, 09:32 PM   #8
Mmnsc's Avatar
Using the MMO on the advise of Equalizer who builds the hydraulic system
Old 08-08-2016, 08:19 AM   #9
edgewant's Avatar
Dexron III
In an effort to get rid of the annoying jack noises I removed all the fluid in the reservoir then added Mobil synthetic and one quart of the Cat additive. After speaking to the Equalizer rep at the Perry FMCA rally I added a quart of MMO (after removing one quart from the reservoir). The MMO seemed to make the noises worse so I added a second quart of the Cat additive. Things are somewhat better but the jury is out until we get into weather with some significant temperature swings.
2013 Berkshire 390RB-60
Toad: 2002 Jeep Wrangler
edgewant
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 08-08-2016, 06:37 PM   #10
The MM oil was added to mine by the Equalizer service guy working on my system. I would guess it is ok. I agree that A heavier or thicker oil would help eliminate the leak down if that's is what it is doing.
