The gas cylinder that assists with lifting and lowering the dining table in my '14 390BH broke (ear for the bolt sheared off). Has anyone had to replace and if so, where did you order? It is a Stabilus Lift-O-Mat 8402XW 0270N 047/13 B 5. Stroke length I measured is from 11.75" to 18". Amazon carries the brand and generally the right size but the attachment point on
one end is not made for a bolt, but rather for a ball/socket joint. Thinking I could just drill through it to fit the bolt but thought I would check with others first.
