Old 09-07-2015, 05:58 PM   #1
15berkxl's Avatar
Dirty power?
While dry camping this weekend I encountered a strange situation. With generator running and the LED lights on in any room when I turn on water pump ceiling lights flicker rapidly turn the pump off flickering stops. Returning home and connecting to home shore power I tested it again and same thing happens so do I have a bad pump or gremlins in the wiring.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 09-07-2015, 06:13 PM   #2
dan-nickie's Avatar
Apparently you're not the only one. See this thread
http://www.forestriverforums.com/for...d.php?p=977062
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 09-07-2015, 06:29 PM   #3
15berkxl's Avatar
Dan wow that's weird.
Wayne
Wayne
Old 09-07-2015, 06:58 PM   #4
Check your transfer switch and make sure the wiring is tightly secured.
Paul
Paulie Boy is offline   Reply With Quote
Old 09-07-2015, 07:01 PM   #5
15berkxl's Avatar
Paul
Paul
The pump and the lights operate on 12 volts don't they what would the transfer switch have to do with that just asking.
Wayne
Wayne
Old 09-07-2015, 07:04 PM   #6
Bad windings in motor?
Papa GLS is offline   Reply With Quote
Old 09-07-2015, 07:24 PM   #7
Wayne, if I'm not mistaken, everything goes through the transfer switch.
Paul
Old 09-07-2015, 07:41 PM   #8
I-RV's Avatar
Only the generator and shore power go through the transfer switch. One horrible thought, Wayne. All of the DC connections like connectors and lugs are crimped. I sure hope that it is not a loose crimp; it would be difficult to find. Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 09-07-2015, 07:53 PM   #9
15berkxl's Avatar
Hank I'm with you I'm hoping it's a bad motor on the pump.
Wayne
Wayne
Old 09-07-2015, 07:59 PM   #10
dan-nickie's Avatar
I have noticed the high speed Flickr on the lights, but I never associated it with the water pump or any other thing. I'll have to check and see if that is what makes mine Flickr.
Dan
Old 09-07-2015, 08:00 PM   #11
Hank, so what you're saying is that none of the house battery current goes through the inverter/converter by way of the transfer switch?
Paul
Old 09-07-2015, 09:30 PM   #12
7 Year Class A RV'er
Certainly can't offer an explanation but I can tell you LED lights have a few idiosyncrasies to them. First, they're polarity sensitive, so the only go in one way to get them to work. They also are very sensitive on grounding requirements. The strangest thing I've seen was on our last RV. I replaced the porch light with an LED that had a motion detector. While watching TV on over the air, the reception would suddenly just drop to nothing. Finally figured out it was happening every time the porch light came on! Truly strange!
2015 Legacy SR340 360RB with 2014 Wrangler Unlimited Toad
Gigi, Poppy and Sadie the Jack Russell (all 14 lbs of her)
Old 09-07-2015, 09:41 PM   #13
B and B's Avatar
Before you go looking for a needle in a haystack, The Convertor might be the cause of the issue. Does this happen just on Battery with the convertor turned off? If it only happens with the convertor on it is falling out of regulation and changing voltage based by higher current of the water pump. If it happens on both, bad pump.
As far as the post above. There are a bunch of bad LED lights that cause Radio Frequency Interference. This will cause interface to TV reception.
B and B
Old 09-10-2015, 10:58 PM   #14
When you cut generator on or shore power both run 12 volt thur 12 volt relay.
Sent from my LGMS345 using Tapatalk
barnettron99 is offline   Reply With Quote
Old 09-10-2015, 11:03 PM   #15
Turn both on with just house battery and see if it flickers. No generator no shore power and no engine running.
Old 09-13-2015, 10:41 AM   #16
gasman94's Avatar
Not to hijack here, but I also have something weird with my LED's. When the living room LED's are on, the bedroom LED's have a faint glow even though the bedroom switch is off. Maybe more sensitive to circuits d/t lower voltage requirements?
Rich
gasman94 is offline   Reply With Quote
Old 09-13-2015, 11:12 AM   #17
tmmar's Avatar
Rich,
I have noticed the same thing but it does not always happen though. Seems intermittent. Was going to have it looked at while at Goshen, but of course it didn't happen then.
Tom and Margaret
2014 Berkshire 390bh-60
Old 09-13-2015, 11:18 AM   #18
gasman94's Avatar
I was going to also, Tom. But not really a big issue and they were so good about taking care of everything else, that I didn't bother.
Rich
power
