Old 01-30-2019, 05:04 PM   #1
planopat's Avatar
Dish wiring for Berk 38A
Iím not a big fan of watching TV when camping so OTA for news suits me fine but the DW wants her shows and Iím being pressured into considering the addition of Dish since thatís whatís available at home. While my 38A is prewired for roof top Wingard Traveler, Iím leaning toward a portable. The wiring originates somewhere in the A/V cabinet and terminates in the cabinet above the passenger windshield. One option is to find a way to get those upper cabinet wires to the outside (front basement?) or option two, install new wires from the A/V cabinet and drop directly to basement below, where the dome connections would be made. My question is, has anyone had experience in how and where these wires are routed in a Berk?
planopat is offline   Reply With Quote
Old 01-30-2019, 07:08 PM   #2
Satellite
I am guessing power to dish, COAX from Dish, and COAX to TV1 and TV2. Mine had COAX to the 'entertainment" shelves in the bedroom and the main room.
Winegard Trav'ler has a control box that would be installed in the compartment above passenger seat, that one is where the multi-wire gets plugged.
If using a direct TV SWM, the power inserter would also be installed in that compartment, and the COAX to dish and COAX to TV1 would be connected to the power inserter. If using more than one TV, then need a multiswitch.
If direct TV noSWM, then just get a COAX Coupler and join the COAX to roof to the COAX to TV1 and put receiver in location where COAX to TV one is run (likely in living room).
2018 FR Berkshire XL 40 C
2016 Jeep Cherokee Trailhawk
BlueOx Avail TowBar
raidernation is offline   Reply With Quote
Old 01-30-2019, 07:12 PM   #3
I have a permanent dish in the campground we have a seasonal lot. I ran COAX from the basement up to the entertainment center above the fireplace in my 40C. I put in a switch for times we are on road and using roof top trav'ler. Run COAX up into wet bay, then i put a wall plate in that compartment so the COAX would run up into the entertainment center. When we are using the external (not roof-mounted) dish, I just attach the COAX to the wall plate in the wet bay.
BlueOx Avail TowBar
Old 01-30-2019, 07:17 PM   #4
The 38A has the same slide as my 40C. You can get into the entertainment center by removing the fireplace and running COAX up the cable path with the other cables and flex pipes. Its a bit tight, but I ran multiple ethernet and COAX cables with the other wiring. Leave slack for the slide movement. I put another wall plate inside the entertainment shelf, and that is what I use the receiver to connect to the COAX.
To be able to close the basement doors when I am connected, I selected to run the COAX into the wet bay, as there is a trap door for the water line. I use it for my COAX and Cat 5 ethernet to my nanostation antenna for wifi.
BlueOx Avail TowBar
Old 01-30-2019, 07:55 PM   #5
Dragonship Captain
Oscarvan's Avatar
Can you get her shows streaming? It's the future and would save you a lot of messing around.
Read about our 2017 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
Old 01-30-2019, 08:54 PM   #6
planopat's Avatar
Thanks. That's very helpful. I'll have to pull the FP this weekend and have a look.
Old 01-30-2019, 08:57 PM   #7
planopat's Avatar
Oscar, I don't dare show her streaming. As a retired nurse she'd be watching medical shows 24 hours a day or 15 seasons of CSI !
Old 01-31-2019, 02:46 AM   #8
Dragonship Captain
Oscarvan's Avatar
I see your problem......
Old 01-31-2019, 10:22 AM   #9
edgewant's Avatar
I have a 2013 Berkshire so what Iím about to describe may not be possible with your motorhome. I used the cable TV port in the inverter/shore power compartment with a non powered booster and a dish tailgater. I also have a roof mounted traveler dish so I used a simple A-B switch to allow selecting the roof or tailgater. The coax coming out of the A-B switch goes to the Dish receiver.
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 01-31-2019, 11:18 AM   #10
planopat's Avatar
That's very interesting. I like the idea and could work in my rig. Since I don't have a roof mount I wouldn't need an A-B switch but out of curiosity, I'm assuming the A-B switch is located in the inside cabinet?
wiring
