11-01-2013, 02:55 PM
DIY project
I was getting tired of having to move my hose from the city water, fresh water and black tank wash. So I found some short white hoses at Camping World and with three 90's and two 2 way Y valves I made an additional water manifold. Now I just have to hook up one hose and by manipulating a few valves I can fill the fresh water tank, be connected to city water and flush out my black tank. It was easy and cost less than $20.
2013 Berkshire 390BH
11-01-2013, 03:23 PM
That is a neat idea although I would highly recommend installing a good anti siphoning or anti back flow check valve in the hose going to the tank flush. I seem to remember being cautioned not to use a potable water hose for the tank flush.
11-01-2013, 03:24 PM
I suggest you put a spring loaded check valve on the black tank flush hose.
edit;
Too
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
11-01-2013, 03:51 PM
Yes, times 3. You need another check valve between the fresh water manifold and the tank flushers. Make sure it is installed in the correct direction.
Valves | Backflow Preventers | Hose Bibb Vacuum Breaker | B170331 - GlobalIndustrial.com
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
11-01-2013, 03:54 PM
I like it although I am a bit worried about the tank flush also. I usually use a old hose for that job. I found some good quick disconnects at Lowe's that make things much easier but spent more than 20 bucks.
Looks like Herk has a fix and cheap also.
11-01-2013, 05:12 PM
Wow, what a tangle of spaghetti.
11-01-2013, 05:24 PM
Love it when someone gives constructive feedback.
11-01-2013, 05:27 PM
Hey, Phil. Was that you that honked at me this morning as I was pulling my 5er down Fulton?
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Rockford, Michigan
11-01-2013, 05:35 PM
Yes that was me Lloyd. Where you heading out camping? Nice looking rig if I haven't told you lately! Are you and Karen planning to go to the St.Augustine FROG rally? Dianna and I where looking at the schedule and are thinking about trying to make it.
Sorry to hi jack.
11-01-2013, 05:50 PM
Hated to hi jack too. Just sent you a PM.
11-01-2013, 06:19 PM
Campin Cajun,
I made something similar but just for the tank fill and city water, a lot less plumbing. I like to use unrestricted pressure for my tank flush it seems to do a better job of getting the sensors cleaned off.
GOOD LUCK
AREA51
11-01-2013, 06:42 PM
I went with three separate quick disconnects and "keyed" in such a way (male/female fittings AND two different brands of quick connects) that it's impossible to hook the black tank flush hose to either of the fresh water fittings and vice/versa. Even with a back flush preventer, I don't want to chance getting sewage bacteria in my fresh water supply.
I may add a splitter on the fresh so I can feed either line from one hose, but BW flush will always be a separate hose/fitting at my house.
Boowho??
11-02-2013, 09:18 PM
Thanks Herk, that's a good idea. I hadn't thought about the back flow from the tank flush. I'll get one of those.
