Old 11-01-2013, 02:55 PM   #1
Campin Cajun's Avatar
DIY project
I was getting tired of having to move my hose from the city water, fresh water and black tank wash. So I found some short white hoses at Camping World and with three 90's and two 2 way Y valves I made an additional water manifold. Now I just have to hook up one hose and by manipulating a few valves I can fill the fresh water tank, be connected to city water and flush out my black tank. It was easy and cost less than $20.
ID:	42168   Click image for larger version
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 11-01-2013, 03:23 PM   #2
mjracsj's Avatar
That is a neat idea although I would highly recommend installing a good anti siphoning or anti back flow check valve in the hose going to the tank flush. I seem to remember being cautioned not to use a potable water hose for the tank flush.
mjracsj is offline   Reply With Quote
Old 11-01-2013, 03:24 PM   #3
Twisty's Avatar
I suggest you put a spring loaded check valve on the black tank flush hose.
edit;
Too
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 11-01-2013, 03:51 PM   #4
Herk7769's Avatar
Yes, times 3. You need another check valve between the fresh water manifold and the tank flushers. Make sure it is installed in the correct direction.
Valves | Backflow Preventers | Hose Bibb Vacuum Breaker | B170331 - GlobalIndustrial.com
HAM CALLSIGN - KC3FFW
Old 11-01-2013, 03:54 PM   #5
I like it although I am a bit worried about the tank flush also. I usually use a old hose for that job. I found some good quick disconnects at Lowe's that make things much easier but spent more than 20 bucks.
Looks like Herk has a fix and cheap also.
Old 11-01-2013, 05:12 PM   #6
rattleNsmoke's Avatar
Wow, what a tangle of spaghetti.
rattleNsmoke is offline   Reply With Quote
Old 11-01-2013, 05:24 PM   #7
Love it when someone gives constructive feedback.
Old 11-01-2013, 05:27 PM   #8
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Hey, Phil. Was that you that honked at me this morning as I was pulling my 5er down Fulton?
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 11-01-2013, 05:35 PM   #9
Yes that was me Lloyd. Where you heading out camping? Nice looking rig if I haven't told you lately! Are you and Karen planning to go to the St.Augustine FROG rally? Dianna and I where looking at the schedule and are thinking about trying to make it.
Sorry to hi jack.
Old 11-01-2013, 05:50 PM   #10
Lloydg's Avatar
Hated to hi jack too. Just sent you a PM.
