Old 09-15-2015, 03:05 PM   #11
I meant ALL filters, not just engine.
mtnlvr is offline   Reply With Quote
Old 09-15-2015, 04:48 PM   #12
Yes do it myself it's not a money thing .im about 20 miles from a place to get it done and it's A hour or so. To Waite that turns into 2 or3 hours the hardest part of the job is not getting the oil out or the filter off its getting the 5 gallons of oil back in the filler tube is a night mare .what I do is put a 8 foot step ladder behind the coach it has a 3 inch hole top step got 3qt funnel and 36 inch of 1 1/2 in tubbing just make sure you put a clamp on tubbing to hold on funnel two things you don't want to happen lose the tubbing in the filler tube or spil the oil
Blazer is offline   Reply With Quote
Old 09-15-2015, 06:38 PM   #13
15berkxl's Avatar
Guess I'm lucky in sorts I have a mobile service that comes to my house services both coach and generator and lubes suspensions. True costs $200 but that includes parts and they take away old oil.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 09-16-2015, 06:07 AM   #14
Fulltime in our Berkshire
KennyGolub's Avatar
Wayne
How did you locate this service ? Google search, word of mouth, etc ?
Thanks,
Ken
Ken & Laurie
2015 Berkshire 400QL
2016 Chevy Colorado
Home is Where we park it
KennyGolub is offline   Reply With Quote
Old 09-16-2015, 06:12 AM   #15
Should be lots of independent service guys around that work on equipment and trucks that would go out to service diesel engines. Not sure if their pricing would be the same though.
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 09-16-2015, 06:30 AM   #16
15berkxl's Avatar
Thanks,
Ken
Ken the RV dealer in Elkhart used them for oil changes so rather than drive the 10 miles for service I called them and have been using them for 13 years now. If you are in the Elkhart area I can give you their number.
Check with your dealer most don't want the hassle of dealing with the old oil so I bet there are more of these than we realize. You can try google or social means to see what's out there.
Wayne
Wayne
Old 09-16-2015, 12:51 PM   #17
Originally Posted by tmmar View Post
Boo,
Yes, there is a fuel filter and a fuel/water separator. The fuel/water separator has a clear yellow bowl on the bottom of it and the fuel filter looks like an oil filter. They should be right next to each other on the passenger side. Just be aware, when you remove the old filter, fuel will continue to flow out until the new filter is installed. Ask me how I know this (LOL!!).
DJP,
I put a Fumoto valve on mine. Very easy to open to drain and close to shut it off. Makes changing the oil easier.
Thanks, Tom.
Boowho??
boowho is offline   Reply With Quote
Old 09-16-2015, 01:06 PM   #18
deebarjay's Avatar
I change my own....had the fumoto on last 3 diesels....I am anal about maintainance....this way I know its done with the right wt. oil and filter. peace of mind is whats its called....and not what I have when I've had a ford shop do stuff.
2008 F250 6.4 diesel with 50 gal aux tank towing a 2015 Rockwood 2109s Minilite.
2015 Miles and nights
10040/31
2016 miles and nights
feb. 380/7......march 540/3
deebarjay is offline   Reply With Quote
Old 09-16-2015, 04:35 PM   #19
15berkxl's Avatar
If you are changing your own be aware prior to 2013 FL chassis some had what is called a rock filter on the fuel line. This means you could have 3 fuel filters. If your chassis not coach was built prior to 2013 a simple call to FL with your vin # will determine if yours has it. They eliminated that filter in chassis model year 2013 so newer you will just have the 2 mentioned.
Wayne
Wayne
Old 09-16-2015, 05:01 PM   #20
tmmar's Avatar
Wayne,
I had an '08 Berkshire and that only had 2 filters - 1 fuel and 1 fuel/water separator(plus the oil filter). Never heard of one with 3 fuel filters.
Tom and Margaret
2014 Berkshire 390bh-60
