Old 06-23-2015, 12:27 PM   #11
Georgia Frog Rally 2018
aceinspp's Avatar
Friend of mine added one and it worked great for him. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 06-23-2015, 04:02 PM   #12
kingwood390bh's Avatar
Do you have a fridge thermometer? Mine indicated 46 on the read out but the thermometer said low thirties inside
kingwood390bh is offline   Reply With Quote
Old 06-23-2015, 09:40 PM   #13
I do not have a fan, looks like for the cost it's worth adding. How did u power it?
mbills is offline   Reply With Quote
Old 06-23-2015, 09:43 PM   #14
I haven't checked with thermometer but I do believe it was getting warm.
Old 06-24-2015, 07:41 AM   #15
tmmar's Avatar
Mark,
It is a super easy install. First, get the one with the 2 fans. Then, there is a clip on the fan that clips onto the fins in the back of the refrigerator to hold it in place and act as a ground. Then there is a wire on the fan that you run to the light inside the refrigerator. You remove the cover from the light and attach the wire to the side of the light that always has power. You can test to make sure that you have the right connection by manually turning the light off and see if the fan continues to run.
As I said, very easy install and makes a big difference in the temp in the refrigerator.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
dometic, fridge
