Old 02-10-2016, 06:28 AM   #11
lgray's Avatar
If replacing the unit under warranty other than Dometicís, you may take a look at the Coleman AC/Heat pumps.
lgray is offline   Reply With Quote
Old 02-10-2016, 07:07 AM   #12
tmmar's Avatar
Would need to make sure the Coleman would work with the Domestic thermostat.
Tom and Margaret
2014 Berkshire 390bh-60
Old 02-10-2016, 03:22 PM   #13
2013 Berkshire 390 BH-60
Jersey Guy's Avatar
My bedroom unit took a crap last summer, I was 6 months out of warranty. Dometic said that there was nothing they can do. She basically told me they are disposable units. $1700 later after parts and labor I put a high capacity unit on. Sounds like Dometic is pushing out some inferior AC units. Time for us to band together and throw some publicity their way.
Mike
2013 Berkshire 390BH-60
Jersey Guy is offline   Reply With Quote
Old 02-10-2016, 04:29 PM   #14
I-RV's Avatar
I sent an email to Dometic reflecting the forums bad experience with the AC units and a link to this thread.
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 02-10-2016, 05:10 PM   #15
Mmnsc's Avatar
Amen
Mmnsc is offline   Reply With Quote
Old 02-10-2016, 05:33 PM   #16
Hank
Curious to see if they respond .
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 02-10-2016, 05:38 PM   #17
Witch Doctor's Avatar
First of all the repair person is full of BS, There is no way to tell if you lost your charge without gages. These units do not have schrader valves on them to check. They are just a disposable unit as they said but not for 1200.00 dollars. They can install a access valve and put dye in to find the leak if that is the problem. There is no way humanly possible to make that call. Now any good repair person can weld an aluminum coil or line. I have done repairs for over 20 years employed 45 mechanics. Trust me you are getting ripped off. If you have a leak it could just be a schrader valve the same as a bicycle. Get a repreableA/C company to take care of it. I don't mean to sound mean or condescending but they just can't guess. I would rather pay 300.00 dollars then 1200.00. The unit only cost retail around 400.00 dollars. If you need more help either repost or send me a PM. I'm so tied of hearing how they keep ripping us off. If you do not have a direct short in the windings, it is repairable and I will tell you how. DO NOT TAKE IT TO A DEALER...Good Luck hope to hear from you.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 02-10-2016, 05:53 PM   #18
Berkshire 390QS
NO3putt's Avatar
The orginial date of purchase is the date you bought your Berkshire, not when FR purchased. If there is a 2 year warrenty by dometic have them replace the unit, you might have to pay for labor for the install, which is easy job once you get it up on the roof. Contact a authorized DOMETIC service center, not just any RV place.
Old 02-10-2016, 06:17 PM   #19
Bluepill's Avatar
As long as it's covered by your extended warranty, a new unit is probably the way to go if the company will cover a replacement rather than a repair.
If the warranty company wants a repair, make sure that you have a reputable A/C specialist handle it and insist on a warranty equal to a new unit.
2008 Itasca Meridian 37H
dometic
