02-09-2016, 12:27 PM
Dometic HP/AC
We have a Dometic High Capacity AC unit with Heat Pump. The unit stopped cooling and heating. Had a technician check it out today. Turns out it has no cooling/heating due to lack of freon. There is no way to add freon to these sealed systems, the whole unit must be replaced.
Since the unit was once replaced under the Dometic warranty it is not under warranty anymore even though the new unit is only 1 1/2 years old. Only a 2 year warranty from Dometic based on the original date of purchase.
This will have to go under my extended warranty. Thankfully I have one as the new unit is about $1200. What a bummer.
02-09-2016, 12:51 PM
Did the service guy say how the freon might have escaped?
That sucks, Dometic should honor a 2 year warranty on a replaced unit.
2013 Berkshire 390BH
02-09-2016, 12:59 PM
Marty, do they go by date of purchase of the coach or the ac unit? As Cajun said, if the warranty is on the ac unit, Domestic should replace the unit under their warranty.
Tom and Margaret
2014 Berkshire 390bh-60
02-09-2016, 04:09 PM
I talked to Dometic and they said that the warranty goes by the date you purchased the coach and Not the date of installation. Had I purchased the replacement unit it would be covered but not if it is a warranty replacement unit.
This is the second unit to fail for the same reason.
02-09-2016, 04:34 PM
legally you have a year warranty from the date of the last repair. Talk to the boss of the person you talk to on the phone. Then when you get that person on the phone, ask for their boss. Amazing how that works.
Karen
Karen and Rick
2020 Forester 2251SLE
Previous: 2018 Berkshire XL 40C
2011 Honda CR-V toad
02-09-2016, 04:37 PM
and it is 1 year from the date of last repair, no matter who replaced it. Warranty work or not.
Karen and Rick
02-09-2016, 05:46 PM
Karen it's been on there longer than 1 year.
I'd like to know what part failed on the unit that a let the freon escape.
02-09-2016, 06:46 PM
The freon leaked from the system and we will never know specifically where the leak occurred. These are now disposable units. You need to change the whole thing.
The tech told me the specific freon that is used in the unit a special license is required to handle that type of freon. If you knew someone in the AC business they could solder in access ports on the lines but with the current design there is no easy way to added freon.
02-09-2016, 06:47 PM
Under what statute?
Karen
Under cover of what local, state or federal statute or authority is there a one year warranty on repairs? This would be good to know.
2016 Berkshire XLT 43a
02-10-2016, 07:05 AM
I had a tech look at my rear unit on my BH last year and he told me that those units were disposable.
Paul
2015 XL 40QL-60
2015 Jeep Wrangler Unltd. Sahara
02-10-2016, 07:28 AM
If replacing the unit under warranty other than Dometic’s, you may take a look at the Coleman AC/Heat pumps.
02-10-2016, 08:07 AM
Would need to make sure the Coleman would work with the Domestic thermostat.
Tom and Margaret
02-10-2016, 04:22 PM
2013 Berkshire 390 BH-60
My bedroom unit took a crap last summer, I was 6 months out of warranty. Dometic said that there was nothing they can do. She basically told me they are disposable units. $1700 later after parts and labor I put a high capacity unit on. Sounds like Dometic is pushing out some inferior AC units. Time for us to band together and throw some publicity their way.
Mike
2013 Berkshire 390BH-60
02-10-2016, 05:29 PM
I sent an email to Dometic reflecting the forums bad experience with the AC units and a link to this thread.
Hank
Gale & Hank- 2012 Berkshire 390BH
02-10-2016, 06:10 PM
Amen
02-10-2016, 06:33 PM
Hank
Curious to see if they respond .
Joe & Lori
2014 Berkshire 390 RB-40
02-10-2016, 06:38 PM
First of all the repair person is full of BS, There is no way to tell if you lost your charge without gages. These units do not have schrader valves on them to check. They are just a disposable unit as they said but not for 1200.00 dollars. They can install a access valve and put dye in to find the leak if that is the problem. There is no way humanly possible to make that call. Now any good repair person can weld an aluminum coil or line. I have done repairs for over 20 years employed 45 mechanics. Trust me you are getting ripped off. If you have a leak it could just be a schrader valve the same as a bicycle. Get a repreableA/C company to take care of it. I don't mean to sound mean or condescending but they just can't guess. I would rather pay 300.00 dollars then 1200.00. The unit only cost retail around 400.00 dollars. If you need more help either repost or send me a PM. I'm so tied of hearing how they keep ripping us off. If you do not have a direct short in the windings, it is repairable and I will tell you how. DO NOT TAKE IT TO A DEALER...Good Luck hope to hear from you.
Coachmen M/H
Concord
2018 / 300 DSC
02-10-2016, 06:53 PM
Berkshire 390QS
The orginial date of purchase is the date you bought your Berkshire, not when FR purchased. If there is a 2 year warrenty by dometic have them replace the unit, you might have to pay for labor for the install, which is easy job once you get it up on the roof. Contact a authorized DOMETIC service center, not just any RV place.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
02-10-2016, 07:17 PM
As long as it's covered by your extended warranty, a new unit is probably the way to go if the company will cover a replacement rather than a repair.
If the warranty company wants a repair, make sure that you have a reputable A/C specialist handle it and insist on a warranty equal to a new unit.
