02-21-2016, 06:14 PM
Dometic ice maker question
I'm having an issue with my ice maker only making ice sometimes. Last summer, the bin always stayed full so I would lift the lever to stop it so I didn't have stale ice all the time. Now it only seems to make ice about once a week or so.
Has anyone experienced this?
2012 Forest River Berkshire 390FL
2013 Hyundai Veloster
02-21-2016, 06:57 PM
Berkshire 390QS
Is your value open all the way? Might not be getting filled with water. Also, are you some place cold? Could be a frozen water line leading to the fridge,
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
02-21-2016, 07:28 PM
I'm in Colorado but it's been in the 50's and 60's the last week or so. I noticed when I was checking in the outside fridge access that there's a tag that says the fridge is equipped with a heater for cold weather and ice maker operation.
Also, I defrosted the freezer today to see if that makes a difference
02-21-2016, 07:45 PM
Berkshire 390QS
Jegstrup, up in Divide? Were down here in Pueblo. We had to replace our water silonid once in the back of the fridge and there is heat tape around it, but not on the plastic line to the silonid. Also we always shut the ice maker off when not hooked up to water since it will keep trying to put water in it when there is no presure.
02-21-2016, 07:59 PM
It's a Dometic rm1350.
I'm out on 115 between springs and penrose at Mountaindale RV Park
02-21-2016, 08:01 PM
We had ours replaced twice it has stopped making ice again. We are not replacing it again I think there is a design flaw.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
02-21-2016, 08:47 PM
I got tired of fooling with the ice maker and the small amt of ice it made so I turned it off, turned off the water to it and bought a portable ice maker. It pours out ice and supply us with tons of it....
I removed the ice bucket and now have extra room for frozen food....
02-21-2016, 08:49 PM
Hmmm, the common thread seems to be that the ice maker is a POS and just forget about it lol
02-21-2016, 08:51 PM
By George I think he's got it.....
02-21-2016, 09:41 PM
Berkshire 390QS
Jegstrup, know what park your in, nice little fire out on ft carson the other day, saw the smoke from our back yard.
02-21-2016, 11:10 PM
I haven't seen any sign of it, but someone here at the park mentioned it this morning
02-22-2016, 02:14 PM
Was having trouble with mine, turns out the freezer was not cold enough to make the ice maker work. They replaced the control board which made the freezer colder, and the ice maker started working again.
Happy Trails
fbconsults
(Forrest and Donna)
2011 Georgetown 378TS
2011 Ford Escape V-6 4X4
02-22-2016, 03:30 PM
Along the same lines, I have a Dometic 1350 also but the icemaker has never been connected. My question is; the refridgerator is in the large slide out along with the dinnet & couch, can the ice maker be connected to a water supply since the slide is subject to moving in & out. The refridgerator is in a position that is located directly above the external water hookup, outside shower and one of the black & gray water dump.
02-22-2016, 04:45 PM
Yup! Ours is in a slide.
Ham KG5LTL.
02-22-2016, 04:57 PM
Are you positive it is never been connected? There is usually a cut off underneath the sink someplace.
Dan
2014 Berkshire 390RB-60
02-22-2016, 05:39 PM
Dometic 1350
It was a brand new replacement for the original that came in my 2011 Georgetown when I brought it - original gave out 2 yrs ago while traveling, Camping World only had a new one w/ice maker, after sitting around their place, Little Rock AR, 4/5 days while they worked me in, didn't want to wait any longer, so left it disconnected. Would have to have waited a couple of weeks longer for a unit without the ice maker.
02-26-2016, 05:51 PM
Looks like mine is working again. Found a leaking line outside coming from the control solenoid. Fixed that and I'm making ice again. 😀
02-26-2016, 07:46 PM
Berkshire 390QS
Great
