Old 07-19-2014, 02:23 PM   #11
What fan kit did you buy? They have two fans in the back already where does this kit go?
Old 07-19-2014, 06:21 PM   #12
Berkshire 390QS
NO3putt's Avatar
We have no fans in the back. Did your unit come with fans?
Old 07-19-2014, 06:24 PM   #13
My 2011 came with two fans in the middle that circulate the air across the coils.
Old 07-21-2014, 05:37 PM   #14
Ericvr4's Avatar
correct they have 2 fans up toward top you can barely see them if you jammed your head in there and look up. I removed cap on roof to let light down, then you can see fans from bottom when you look up. I have yet to see them turn on it was 98 out when my fridge would not go below 42. I bought a 3 fan kit, I mounted on bottom by access panel all In between coils and wiring blowing up towards roof. they have thermostat in line on wire I believe it turns on at 85 degrees, which I mounted near a relay that's warm so they run a lot. I also mounted the interior fan kit off light. all probably over kill but when my kids go in out of fridge a lot, it holds 34 degrees in fridge now. but the ammonia system on my 4 door fridge. was replaced after our first camping trip, all ammonia leaked out. so maybe tech did not hook those fans back up? I would have to take fridge out check it? Good luck all. as I think these dual fuel fridges are weird, but I do get it when you have run off propane.
now if I can get someone to tell me how to get front ac unit to cool better?
2011 Berkshire 390BH
Ericvr4 is offline   Reply With Quote
Old 07-21-2014, 05:49 PM   #15
Ericvr4's Avatar
fans
here is pic of interior , I will try to get exterior .
Old 07-23-2014, 07:25 PM   #16
Ericvr4's Avatar
here are 3 fans installed very tight getting them in there but maid huge difference
Old 07-23-2014, 08:10 PM   #17
klucas's Avatar
This is great info. I need to do the same. What power source did you hook into? Does it have a t stat? Thanks ken
klucas is offline   Reply With Quote
Old 07-23-2014, 08:29 PM   #18
Ericvr4's Avatar
in little black termination box, they tell you what terminal to hook in, i cant remember rt now?. yes it came with in line thermal senor turn on about 85 degree , in picture they have you would to remove fridge to mount up high in back. here is link hopei t works. good luck. Dometic add-on Frame Fan bracket, kit 2 fans, switch, & wiring - RV Cooling Unit Warehouse
Old 07-23-2014, 10:30 PM   #19
klucas's Avatar
Thanks for the link. I will be ordering this also.
Old 07-23-2014, 10:53 PM   #20
Phat Phrog Stunt Crew
elind's Avatar
When I had my RM1350 it was slow cooling in the warm weather. My next step was to add the fans inside and outside the frig. But I traded the TT for a 5er instead before I did it.
2014 Wildcat 327ck
elind is offline   Reply With Quote
dometic
