If you are frequently boiling the batteries dry, you might make some adjustments on your Magnum ME-ARC control.
In Setup > 01 System Setup > 01D Max Charge Amps. The default is 200 ADC. You could reduce that.
Setup > 03 Charger Setup > 03E, you can set a Max Charge Rate of less than 100%
I also seem to recall, but can't find in the manual, the ability to specify the Amp-hour capacity of the house batteries. I think mine is set to 400 AmpHours, although I think the real capacity is 440 AmpHours. I think that the Bulk Rate charging is set to 20% of the AmpHour rating, so I get about 80 Amps in Bulk charge. But, before I found that setting, it was closer to 90 Amps.
–Gordon
