Old 01-02-2019, 08:36 AM   #1
mckyver's Avatar
Door striker pin ( berkshire XL )
Has anybody had a problem with their main door stiker pin beeing loose ! Cannot tighten it , it mouves up and down , sometimes doorc stays locked.
mckyver is offline   Reply With Quote
Old 01-02-2019, 10:16 AM   #2
tmmar's Avatar
I believe that the fact that it moves is done on purpose. It allows for the twisting and movement of the coach body when travelling down the road. If it didn't move it would probably break either the locking mechanism on the door or the shear off the striker pin.
Tom and Margaret
2014 Berkshire 390bh-60
Old 01-02-2019, 11:18 AM   #3
I saw another thread awhile ago about a similar problem. They were having trouble getting to the tightening screw/nut. I can’t find it off hand but try the search function in various wording and it should help. I know there are other folks with different brand coaches who have dealt with it also so help is out there.
2016 Berkshire XL 40A towing 2016 Jeep Wrangler.
Prior to this Jayco fifth wheel: 24' Eagle, 30' Designer, and 40' Jayco pinnacle.
Igave is offline   Reply With Quote
Old 01-02-2019, 11:45 AM   #4
mckyver's Avatar
Originally Posted by Igave View Post
I saw another thread awhile ago about a similar problem. They were having trouble getting to the tightening screw/nut. I canít find it off hand but try the search function in various wording and it should help. I know there are other folks with different brand coaches who have dealt with it also so help is out there.
Thanks will look into.
Old 01-02-2019, 01:33 PM   #5
Royston's Avatar
I am sure it is supposed to move.
I have attached a file that may (or may not) help
File Type: pdf PTL Preferred Door Latch Adjustment.pdf (4.70 MB, 84 views)
2011 Berkshire 390RB (Front airbag upgrade & 275/80R tires)
2016 Ford Edge SEL 3.5ltr, Blue Ox baseplate, Ready Brute Elite tow bar, Brake Buddy Advantage Select
Royston is offline   Reply With Quote
Old 01-02-2019, 04:49 PM   #6
dan-nickie's Avatar
It is supposed to move up-and-down. I never thought about the reason why, but the above explanation is probably correct.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 01-02-2019, 05:54 PM   #7
Vince and Charlette's Avatar
It's supposed to move up and down. You may notice the later model Berks (mine is a 2018) have a soft close feature on the door and a hard latch feature. For day-to-day use, gently close the door and it will latch and even be able to be locked in that position. However, before you start driving, give it a firm close and it will shift the pin into the upper position for a more positive/safe lock. Coming from a Georgetown, it took the whole family a long time to get used to not slamming the door every time we went in and out.
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 01-02-2019, 10:59 PM   #8
I asked Mitch at the factory about this pin when I was there for service and was also having a problem with locking the door and he said that it suppose to move. I was having the issue that the pin wasn't moving as freely as it supposed to lock would just slam against it without engaging.
Now when my door would just get slammed without engaging, I know to move the pin down and then it works
Alex and Valerie
2014 Berkshire 400BH
AlexG is offline   Reply With Quote
Old 01-03-2019, 08:50 AM   #9
mckyver's Avatar
Thanks will help.
berkshire, door
