Old 06-17-2014, 08:10 PM   #1
RKC02's Avatar
Draining the Fresh Water Tank
I want to drain, flush, and refill my fresh water tank in prepping for a trip (been sitting for about 6 weeks). Problem is that tiny drain valve in the tank($&@!)
Does anyone know a better/faster way to drain the fresh water?
2014 390RB-60 "The Shire"
RKC02 is offline   Reply With Quote
Old 06-17-2014, 09:08 PM   #2
ceedog's Avatar
I open the valve leading from the water pump & turn the pump on along with the dump valve being open. It empties fairly quickly that way.
It ain't easy being me...I've tried.
ceedog is offline   Reply With Quote
Old 06-17-2014, 09:12 PM   #3
RKC02's Avatar
Thanks ceedog - i'll give it a try.
Old 06-17-2014, 09:12 PM   #4
Mbh818's Avatar
I do the same. Just need to make sure you open the valve next to the pump so it dumps the water out the bottom instead of pumping it into the coach. You'll see it. Then remember to close it as well. I will also slightly, and i am slightly, increase the height of the driver side jacks by maybe 1-2 inches. That angles the motorhome just enough to push the water over to the passenger side of the tanks, where the drains are located.
Mike Hollar
2014 Berkshire 390BH-40
2012 Chevy Equinox - TOAD
Mbh818 is offline   Reply With Quote
Old 06-17-2014, 09:34 PM   #5
You can also unscrew the valve entirely, but that sort of defeats the purpose of having a valve in the first place.
2011 Traverse LT, 3.6L, FWD
drain, fresh water, tank, water, water tank
