Old 07-18-2015, 05:52 PM   #1
dan-nickie's Avatar
Draining Water from Air Tank Maintenance
Another goofy question. I just don't want to break something.
I was trying to pull the lanyards behind the front tires this morning.
I couldn't get the best position on them but did pull them pretty hard.
I was afraid to pull harder and have the lanyard come out in my hand.
Are they really that hard to pull?
Do you use something (tool with hook) to reach in the pull them.
The engine and therefore compressor was running during this time.
Should I try it when it does not have as much pressure built up?
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 07-18-2015, 07:06 PM   #2
tmmar's Avatar
Dan,
I usually do that with the engine off. I would try it with the engine off to see if it makes a difference. I don't remember them being all that hard to pull.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 07-18-2015, 08:05 PM   #3
dan-nickie's Avatar
I had mu shoulder wedged in between the tire and fender pretty good to reach it.
I am wondering there is any chance it is going to drop down on me?
Dan
Old 07-18-2015, 08:23 PM   #4
Mmnsc's Avatar
Dan
When I tried to drain the air tanks, I pulled so hard that the loop on the end of the wire opened. I left it untill I got to Freightliner and had them drain the tanks and repair the loop. It can be hard to pull.
Mmnsc is offline   Reply With Quote
Old 07-18-2015, 08:40 PM   #5
ernest917's Avatar
I purchased a long chrome rod with a handle on one end and a hook on the other... Got it from a truck stop.... Works great because I don't have to crawl underneath......
ernest917 is offline   Reply With Quote
Old 07-18-2015, 09:16 PM   #6
dan-nickie's Avatar
Originally Posted by Mmnsc View Post
Dan
Yea, I was afraid something like that might happen if I kept pulling and harder so I stopped.
Thanks, I'm going to look for something like that.
Dan
Old 07-18-2015, 10:03 PM   #7
Dan don't have your arm between the tire and the fender. On mine with the 275 tires there isn't much room. I think the might have redesigned the newer MH so you might have more room. Funny I haven't pulled mine in a long time. I really forgot about it. I guess I should give it a pull soon.
Old 07-19-2015, 10:14 AM   #8
tmmar's Avatar
Phil, PUHLEEASE!! This is a family site!!
Also, with the air dryer that our coaches have, I really don't know why they say you need to drain the tanks. The air dryer should remove any moisture. Also, when ever I have drained the tanks in the past, nothing but air has come out. Also, here is the hook puller that I purchased.
Amazon.com: RoadPro R-7845 36" Heavy Duty 5th Wheel Pin Puller: Automotive
Tom
Tom and Margaret
Old 07-19-2015, 10:36 AM   #9
Tom
And Phil says that *I* scare him sometimes. Sheeesh!!!
Boowho??
boowho is offline   Reply With Quote
Old 07-19-2015, 10:58 AM   #10
15berkxl's Avatar
FL chassis should have an auto bleed system at least my previous FL chassis did. Those who have attended training in SC maybe able to confirm.
Wayne
Wayne
15berkxl is offline   Reply With Quote
drain, maintenance, tank, water
