Old 01-06-2016, 06:57 AM   #11
Originally Posted by Paulie Boy View Post
Attachment 97299
Mike, if you have this unit with the serial number K333 or lower this service bulletin is to replace the duck bill valve. Call the RV department at 800-545-9086. They don't cover labor anymore. Just the part noted on the sheet.
Paul
I'm actually try to get the labor for free! It takes two guys to get my fridge out because it's a 12" above the floor.
Paul
Paulie Boy is offline   Reply With Quote
Old 01-08-2016, 02:15 PM   #12
stephencamiolo's Avatar
To get the rust off the slide rails I would put CLR in a spray bottle and clean it off as best as you can
Stephen
stephencamiolo is offline   Reply With Quote
Old 01-08-2016, 02:39 PM   #13
fredhardy's Avatar
Please see my write-up under Residential Refrigerator regarding the process to remove the refrigerator, do the warranty work, and reinstall it. It's a 2 man job.
Fred Hardy
Phoenix, AZ
2014 Berkshire 390BH-60
2007 Explorer Sport Trac
fredhardy is offline   Reply With Quote
Old 01-08-2016, 02:50 PM   #14
Fred, I took a screen shot and saved it. Had whirlpool tech here today, took one look at it and ran for the hills. Called Whirlpool again and they said I had to make the back of the fridge accessible for the tech to work. He absolutely refused to touch it. I went through great lengths explicitly explaining everything to everybody about the conditions of this unit. Needless to say I'm pissed!
Paul
Old 01-11-2016, 08:34 AM   #15
mikeborny's Avatar
Attachment 97299
Paul
Paul,
What was the problem that the duck bill valve caused? I have noticed a mildew smell from under sink, but can see no leak. I did notice water in basement but not directly under fridge. I can see no water damage or leak when I took off cover under fridge. I thiught these connections might be the problem but they are not.
Name:	ImageUploadedByForest River Forums1452522838.121066.jpg
Mike & Amy + 3 and the dogs!
2014 berkshire 390bh-40
mikeborny is offline   Reply With Quote
Old 01-11-2016, 09:15 AM   #16
Freezer defrost collects under the freezer drawer and drains on the floor from under the freezer drawer. It suppose to drain to an evaporate tray behind the freezer.
Old 01-11-2016, 11:38 AM   #17
mikeborny's Avatar
That is most likely my dampness in basement and why i had the mildew smell by sink area. Will have to wait until winter thaws before investing further.
Old 01-11-2016, 11:53 AM   #18
gasman94's Avatar
Yep, that's what mine is doing. Anyone do a 390FL yet?
Rich
gasman94 is offline   Reply With Quote
Old 01-11-2016, 01:46 PM   #19
Rich is yours raised off the floor like mine? BTW are you off the walking wounded gig yet.
Old 01-11-2016, 02:52 PM   #20
gasman94's Avatar
Paul, mine is on the floor..street side slide over the water bay. And yes, I am back to work and feeling great! Problem is, 7 weeks off makes you start thinking a lot about retirement
Rich
slide, slide out
