Old 03-27-2017, 08:07 PM   #1
ernest917's Avatar
Driver's Power Seat
Where's the fuse for the driver's power seat???? I've looked and looked..... Gotta have a blown fuse cause it won't work all of a sudden.....
ernest917 is offline   Reply With Quote
Old 03-27-2017, 09:04 PM   #2
dan-nickie's Avatar
Sometimes it's an inline fuse actually under the seat.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 03-27-2017, 09:05 PM   #3
ernest917's Avatar
Haven't looked there.... Thanks....
Old 03-28-2017, 09:39 AM   #4
BamaBob's Avatar
And?
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 03-28-2017, 10:23 AM   #5
ernest917's Avatar
Still haven't looked there.... It's on my LIST !!!!
Old 03-28-2017, 11:11 AM   #6
Dragonship Captain
Oscarvan's Avatar
I have one of those. Get everything done and then it.... gets even longer every time I take it out.
2020 RAM 3500 DRW Long Horn. In the hunt for a Palomino TC, formerly a 2017 Berkshire 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
Old 03-28-2017, 04:26 PM   #7
ernest917's Avatar
My problem is my list contains issues that you can't do in 30 minutes.... Of course my 30 minute items always take me 3 hours anyway.....
Old 03-28-2017, 05:42 PM   #8
AREA51's Avatar
Try the outside compartment under the drivers seat. My coach has 3 separate fuse compartments in that area.
GOOD LUCK
AREA51
AREA51 is offline   Reply With Quote
Old 03-28-2017, 05:52 PM   #9
ernest917's Avatar
AREA51.... Checked there first.... All ok...
Old 03-29-2017, 07:55 AM   #10
silver's Avatar
Did you check the Freightliner fuse box tucked in the upper left corner of that compartment? You would not know it is a fuse box unless you open it then surprise.
silver is offline   Reply With Quote
Old 03-29-2017, 09:31 AM   #11
ernest917's Avatar
Didn't know that.... Thanks...
Old 04-17-2017, 01:07 PM   #12
I you haven't already done so, recommend checking the electrical connection under the seat to make sure it is tight. On several occasions, my power driver's seat hasn't worked after turning it around to 'camp mode' and then turning it back around to 'drive mode'. Visually, the connection will seem fine but if it's not tight....no power to seat.
pplatts is offline   Reply With Quote
Old 08-13-2017, 07:24 PM   #13
ernest917's Avatar
Sure enough - it WAS the connection under the seat..... Thanks.....
power
