Originally Posted by lefaivre
My table stays up but it keeps pulling out of the wall. Any suggestions
Is the table mechanism itself pulling from the wall or the table top loose and moving away from the wall. My table top became loose so I dropped it down about half way, removed the screws that were holding it together from the bottom. Once the screws were out I drilled four 1/4 inch holes through the top and mounting bracket that is on the bottom side of the table. I counter sunk the holes on the table top and put four flat head bolts through and put lock washers and nuts underside to fasten the table top to the bracket. Mine has not moved since I made this repair.
If that is your problem, this was an easy fix. If the bracket pulled from the wall that is a whole different solution.
Good luck
