Old 08-30-2016, 08:54 AM   #11
CAT-RN's Avatar
Dry camping
Drill a 3/8 inch hole in the floor to let any water out that might over flow. Then pull overflow tube up above the tank. If it overflows water goes out the 3/8 hole. But it won't siphon out !! The hole left in the floor where you pull your overflow hose up will also drain any water that come out the tube. Just sand off all the excess silicon sealant that's there.
Then cut a 8" or 10" hole in the wall between the water compartment & the storage compartment. Then you can open the door in storage look right at the water tank and watch it fill. Too hard to unsnap the water compartment door. I'll attach a pic of the hole I cut.
In the pic you can tell that my water tank is empty. And I also have a lid that you can screw into the hole to close it up if you would want to.
RussellClick image for larger version
Name:	ImageUploadedByForest River Forums1472565255.527228.jpg
CAT-RN is online now   Reply With Quote
Old 08-30-2016, 09:08 AM   #12
bob dirt's Avatar
Obviously there is a leak somewhere before the pump but most likely at the inlet of the pump. It needs to be found so the system works before your next dry camp outing. I always check everything before I leave home
2016 Forester 2401WS MBS
Life is short...eat the cookie
bob dirt is offline   Reply With Quote
Old 08-30-2016, 10:51 AM   #13
MotoxDad's Avatar
RussellAttachment 118813
My Berk has a spot cutout looks like from the factory to me, so you can see the fresh water tank. It's in the water manifold bay and let's me see when the tank is full.
John
2014 Berkshire 400BH
Motocross Dad
MotoxDad is offline   Reply With Quote
Old 08-30-2016, 11:59 AM   #14
Cyclone
beipers's Avatar
Simple stuff first. Is the valve used to winterize the pump and plumbing system fully closed? If you have it between positions, it will act just as you describe, yet the water doesn't run out of the tank. Been there done that on my previous Berk.
2013 Silverado 3500 D CC, 2015 Jayco Eagle Premier 375bhfs
2015 SOB 5th Wheel
2013 Chevrolet 3500 CC, DD SRW
1 Wife, 2 Kids under 5
Camping nights: 2015 - 19, 2014 - 39, 2013 - 48
beipers is offline   Reply With Quote
camping, dry camping
