Old 09-17-2015, 02:49 PM   #1
Easiest, most direct route.
To wire the sewer dump pump. Calls for 12v dc, 16 amps. I have 10 ga. wire just trying to figure a safe place to connect to. Don't want the t.v. shutting down when I flip the switch for the pump. Thanks in advance for your input.
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 09-17-2015, 03:11 PM   #2
dan-nickie's Avatar
Isn't it going to be close to the battery bay? Use an inline fuse.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 09-17-2015, 04:07 PM   #3
NV245's Avatar
I purchased our 08 as second owner, so I don't know if what mine has was done at factory or not, but I have a remote macerator and was looking to wire it. I found four wires in the water distribution bay, and after testing and trial and error, found that two of the wires operate a relay, the other two are relay switched power and a ground. I installed a light duty switch and installed connectors on he output wires. I haven't traced the wires back to their source, so I don't know how it was done, and I am curious if it was factory or a well done addition.
NV245 is offline   Reply With Quote
Old 09-17-2015, 05:38 PM   #4
gasman94's Avatar
Hey Joe, I agree with Dan. Battery bay is really close. My plan was to fuse a wire from a chassis battery to the water bay.
rich
gasman94 is offline   Reply With Quote
Old 09-17-2015, 05:59 PM   #5
rich
So you and Dan are talking about going right off the terminal of the coach battery ( just one right ). Positive to fuse, then to switch. Then just run a ground to the other wire to motor? Also if the motor says it draws 16 amps, go with a 20 amp fuse ?
Joe & Lori
Old 09-18-2015, 12:59 PM   #6
Coach battery bay is all the way down at the rear, doesn't look far till you crawl under that beast. OMG ! Not the easiest getting around under there, especially trying to get past the axle. Any other thoughts ?
Joe & Lori
Old 09-18-2015, 01:05 PM   #7
Anyone know whether tapping into the side of this thing that says chassis bat. on the right hand side would be kosher ? This is where the house batteries are just to the rear of the rear wheels.
Joe & Lori
Old 09-18-2015, 06:21 PM   #8
dan-nickie's Avatar
Joe, My thought was if it draws 16 amps that it would not be something I would want to splice into some other wires not knowing if the load would be too much.
So I figured it needed to go either to the DC fuse panel up front to an unused position or to the battery direct. Battery is closer.
I have stayed away from any projects that would require running wire too far under the coach for the same reasons you state. I can't get under there.
Dan
Old 09-18-2015, 06:37 PM   #9
gasman94's Avatar
Plus the longer that you run the wire for a high amperage load, the greater the concern for an adequate (read larger and more expensive) size wire.
Rich
Old 09-29-2015, 01:17 PM   #10
Just ran the 10 gauge from chassis battery compartment over to the wet bat compartment. How can anything so mammoth be such a pain in the butt to work on ?
Must be a walk in the park for the mechanics that have to work on these engines. Not !!
Joe & Lori
« Keys | Hello !! »
