Old 02-22-2015, 12:37 AM   #11
There isn't much more you can do about it tonight, but if it were me, tomorrow I would go ahead and pull the breaker and hit the home improvement store. If you have a GFI on that circuit, I would pick up a new GFI, breaker, and if you don't have one yet, an inexpensive voltmeter.
In turn, I would switch them out and see if that resolves the problem. Worst case, you end up with a spare something or other that would be good to have around anyway.. and if it turns out NOT to be the GFI, then the new one is more than likely going to be of higher quality than the one you pulled. All told it shouldn't be more than $20. Less if there is no GFI on that circuit.
Good news though!! It's NOT your cord, power supply, transfer switch or converter.
If a breaker and GFI switch out doesn't cure the problem, then I would first pull all of the outlets.. starting with the one the electric heater was plugged into and inspect for damage. If there is nothing obvious there then you'll need to do a continuity test along each leg of the circuit.
If you DO end up having to run new lines it's generally not that big of a deal. Just attach the new line to the end of the old line and then feed/pull it back through from outlet to outlet.
Hope it works out.
rana is offline   Reply With Quote
Old 02-22-2015, 03:39 AM   #12
edgewant's Avatar
The following is off topic so I'll be brief:
Yarome. The status under your name is "docker". What is that and how did you get that status?
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 02-22-2015, 04:05 AM   #13
No Problem! PM sent...
Old 02-22-2015, 08:47 AM   #14
I would bet that the breaker on the Magnum inverter is tripped. Don't plug your heater into inverted plugs. On top of the inverter is a rocker type switch go and reset it.
Old 02-22-2015, 09:12 AM   #15
jmgllt's Avatar
I have a 2012 390BH, where is the inverter located?
jmgllt is offline   Reply With Quote
Old 02-22-2015, 09:19 AM   #16
Drivers side rear second compartment. The location is different from year to year but it's full of electronic stuff. It is a black box about 12x6x3. A rocker switch on top is a reset breaker and will blow if to many Amps are used in that line.
Old 02-22-2015, 09:21 AM   #17
jmgllt's Avatar
Thanks I'll check it out.
Old 02-22-2015, 09:23 AM   #18
Name:	ImageUploadedByForest River Forums1424618544.876869.jpg
ID:	70032Click image for larger version
Name:	ImageUploadedByForest River Forums1424618573.290256.jpg
Old 02-22-2015, 09:34 AM   #19
jmgllt's Avatar
That fixed it THANKS!
Old 02-22-2015, 09:35 AM   #20
Cyclone
beipers's Avatar
Jmgllt. Phil is right on the money. I had this happen on my 2013 390BH and it was the inverter pass through breaker.
You were to fast. Glad to see it fixed.
2015 SOB 5th Wheel
2013 Chevrolet 3500 CC, DD SRW
1 Wife, 2 Kids under 5
Camping nights: 2015 - 19, 2014 - 39, 2013 - 48
beipers is offline   Reply With Quote
electric
