Old 09-23-2015, 02:56 PM   #31
Originally Posted by Bluepill View Post
Great resources. Thanks!
BP
X2 Thank You Wmtire for this material.
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 09-23-2015, 05:22 PM   #32
X3!!!
boowho??
boowho is offline   Reply With Quote
Old 09-23-2015, 10:17 PM   #33
Originally Posted by wmtire View Post
Electrical safety (really a must read). A little bit of everything. Make sure to scroll down and click on all the different parts.
RV Safety | No~Shock~Zone
and for sure read this from Mike in the No-Shock-Zone
RV Electrical Safety: Part IV – Hot Skin | No~Shock~Zone
I think this is the most relevant article I've written about avoiding over-voltage damage with a 30-amp/120-volt outlet mis-wired with 240-volts. Mis-wiring a 120-volt RV outlet with 240-volts | No~Shock~Zone
But remember, an open neutral on a 50-amp/240-volt outlet will do much the same thing, since loading one of the legs will result in the opposite leg voltage increasing to dangerous levels. So when the air conditioner tries to kick in, the microwave and refrigerator can be damaged.
Either circumstance will result in a lot of expensive damage to your RV's electrical system in a matter of seconds. If it doubt, DO NOT plug in.
Mike Sokol
The No~Shock~Zone
jmsokol is offline   Reply With Quote
Old 09-24-2015, 04:50 AM   #34
Originally Posted by jmsokol View Post
Another great article. Thanks Mike.
Joe & Lori
Old 09-24-2015, 12:17 PM   #35
Tom48's Avatar
Originally Posted by oldtool2 View Post
I have been considering solar and did quite a bit of research for use on my 5er. I have been told this is a good system and comes highly recommended.
http://www.amazon.com/dp/B00BSZUHRC/...O9FZ5FP8&psc=1
They make a 200 watt system also but most everyone recommends going with the 400 watt panels.
Jim
Jim, I have looked closely at Renogy and Go Power and of course the WindyNation.com stuff that I bought. Renogy is about three miles from my house and Windy Nation is over in Ventura, CA 100 miles away. I can will call Renogy and WN ships overnight to my location UPS at no additional cost.
The Renogy and WN basic stuff seem to be almost identical. Both are a bit sparse in documentation for their, charge controllers, both seem to use similar China cheapy basic controllers. I went with the still poorly documented WN upgraded controller that they now put with some of the packages. The Go Power systems may or may not be better, but their controller is better documented and I really like the specs on it. Their systems are a lot higher priced but I could not see how they were better Except the controller and the little gadget they have to create an entry point from the roof, for the wiring, seems really neat.
I think I concur that 200 (which we have) is enough, but for long haul without worrying or for less sunny places than here in SoCal, 400 is better. Some say 100 watts per battery so my friend with 400 quickly learned that his 2 batteries were full by about 10 am most days so he added two more big 6 volt Batts and runs his 2000 watt commercial grade (pronounced $800) inverter indiscriminately. We have three Grp 24 size batts and I never turn the house main power (12v) off and I have UNPLUGGED the converter charger so that it does not try to run off my ($345) 2000 watt inverter when I turn it on the full house. Our needs are met just being a little bit prudent about using the inverter power.
Then we looked at our two panels flat on the roof versus One standing with legs being manually pointed directly at the sun all day, the one produces about 80% as much as the two laying flat during most of the day if we move the one diligently to follow the sun.
Good Luck, Solar is good anyway you slice it but no one should bother with those over priced little 5 to 40 watt GADGET class packages. They are only good as a trickle charger if you store outdoors.
Tom48 is offline   Reply With Quote
Old 09-24-2015, 05:20 PM   #36
Thanks for the information, I appreciate it. If I do get solar it won't be till next spring so still have time to do some more research.
I have learned one thing, Harbor Freight doesn't carry anything I can use when it comes to solar for my trailer, LOL!
As for laying the panels flat, I am not interested. I am also not interested in adjusting the panel location every hour. That is the reason I am thinking about a 400 watt system.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 09-24-2015, 06:51 PM   #37
silver's Avatar
Tom48
We Berkshire owners have Magnum Energy Inverters in our coaches. One question I have had is with solar would you wire the solar controller directly to the coach battery pack. Is there any issue with it feeding back into the Magnum Inverter? Do you need something like a shunt/diode block to protect the Magnum Inverter?
Have ou any experience here? I have seen nothing written regarding this.
silver is offline   Reply With Quote
Old 09-24-2015, 07:28 PM   #38
Tom48's Avatar
Originally Posted by silver View Post
Tom48
For starter I am just a lowly 30 amp TT guy with experience working with or on 30 amp motorhomes too. But we run solar through it's own charge controller then the controller direct to the battery bank. Appropriate fuses everywhere along the way. The good controllers allow some latitude in choosing charge voltages and trickle/maintainer voltages. Nothing we have seems to be affected adversely at all.
Old 09-25-2015, 04:13 PM   #39
Bluepill's Avatar
Thanks for the great write-up.
Just to be clear: This is not a challenge, but I want to make sure that I understand correctly.
I think my math is correct. A single panel lying flat produces 50% of your power, but by sun-tracking it produces 80%. That is a 60% increase in efficiency. Most sources quote about 30%. Is that based on metered amp-hours, time to full charge, or what?
Second question: Is there an inexpensive automatic solar tracker available for 100W panels?
2008 Itasca Meridian 37H
Old 09-25-2015, 05:30 PM   #40
Tom48's Avatar
We
First answer, the numbers you researched might be more accurate than mine. Mine is just an anecdotal guesstimate by looking at his amp charge rate vs My charge rate when he has one panel facing the Sun perfectly and I have two panels laying flat on my roof. There are of course factors like at high noon mine are just about perfectly pointed at the Sun. So the effect is probably more dramatic at 9-10 in the morning or 3:to 4 in the afternoon. It also might be the fact that mine are nearly charged up and start drawing a slower charge rate than the maximum that is available
Second question trackers. I'm not aware of anything that you could use in a mobile environment as a tracker and the pole mount systems that I have looked at for a ground-based system are not cheap. I have never explored the retail cost of an automatic tracker for small panels. The industrial stuff you see in big fields it is pretty expensive looking. Good luck with that. I'm just happy for my 200 laying flat on the roof and hope I can squeeze one more up there someday soon for a total of 300. Again, the rule of thumb that I have read it is 100 watts per good deep cycle battery. Both renegy and windy nation show you various pacages to look at. The best thing is the packages come with mounting brackets wires connectors everything. The packaged system from go power might be a little nicer but it's nearly twice as expensive. For me, those are the options. And if you have a reasonable amount of DIY skill, I can see no reason to pay an installer. Best of luck
battery, electric, electrical, inverter
