04-29-2015, 01:47 PM
Electrical head scratcher
My Berkshire 390bh-60 is at Camping World for a surge protector installation. They called this morning telling me that when they plugged the power in the lights were "strobing" and the 110 outlets had no power. Any thoughts?
04-29-2015, 01:56 PM
So let me see if I have this right. Camping world is hooking up a new surge protector and its not working right and instead of them figuring it out and fixing whatever they did wrong they call you? Yup you went to camping world alright.
2019.5 Rockwood 2509S
04-29-2015, 01:58 PM
Wondering the same myself
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
04-29-2015, 02:36 PM
I generally try to approach a problem by thinking first, "how could I create that condition if I wanted to?". The only thing I can think of in your situation is to kill all the breakers, except the overhead lights, then have my trained chipmunk slip behind the power distribution box door and flip the overheads off and on repeatedly to the tune of "Living in America".
But whata I know!?
04-29-2015, 02:37 PM
But whata I know!?
I was thinking hells bells.
TURBS
04-29-2015, 05:31 PM
Thanks for the helpful post fellas.
Paulie, obviously they did not install it correctly. IF they cannot figure out what they did. Have them take the surge protector back out and try to plug in and see if the same thing happens.
If not then the surge protector could be bad or like I said they did something wrong.
2013 Berkshire 390BH
04-29-2015, 05:34 PM
You may want to try an inverter reset.
04-29-2015, 05:48 PM
Installing a hard wired surge protector is not very difficult. I would think that even CW could handle that job. I wonder if they disconnect the battery (I would) when they installed it? That would not explain the AC issue. That's all I got sorry but I'm at a loss as to how that would get screwed up.
04-29-2015, 06:04 PM
Then again, you may want to give STRONG consideration to picking up your RV at your earliest opportunity. When I take something in for installation/service, and that place calls ME to help them troubleshoot an issue, that tells me I've taken it to the WRONG place!
19xx Wife (named Melissa)
2014 Akita (named Mizuki)
2015 F250XLT 6.2l V8, 4x4, Supercrew, 3.73 Rear
10K WD Equal-i-zer Hitch
2015 Coachmen Catalina 273BH
04-29-2015, 06:07 PM
Let me clarify before the lynch mob gathers. Prior to installing the surge protector, CW techs plugged the 50 amp cord into a supply line discovering the issue with the lights "strobing" and the 110 outlets without power. They found a loose wire at a connection in the transfer switch. All is well now with the systems.
04-29-2015, 06:14 PM
TURBS
Hmm -- could be back in black.
04-29-2015, 06:20 PM
Ask one who had not one, but two, Fantastic Fans installed BACKWARDS!! and get this, by their Technician of the Month!!!!
04-30-2015, 12:51 PM
I'll pick up my rope...lol. Glad you got things worked out Paulie.
04-30-2015, 01:06 PM
Wow. Only at CW could that happen. Can't believe they called you instead of disconnecting the surge protector and see if the problem persists and/or as others have stated, turn all breakers off, then back on one at a time to isolate the issue.
2015 Legacy 340KP
2012 Wrangler Sport
04-30-2015, 01:23 PM
usually when you have crazy things going on with a circuit, the neutral is most of the time the culprit, and finding where the problem is sometimes takes forever, and very mind boggling experience, have been there more time than I like to think about, in the past, retired now don't have to deal with it anymore,
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
