Old 07-16-2011, 07:58 AM   #11
I have a 2011 39QS and i know if you have the disconnect in the stairwell by door on and your inverter on the plug in the bedroom on top of the dresser works while you are driving my wife uses it to charge her laptop
salexander is offline   Reply With Quote
Old 07-14-2012, 05:10 PM   #12
GHodge's Avatar
In my 2011 Berkshire 309RB-60 the only available outlet supplied by the Inverter is the outlet located in the 1/2 bath.
GHodge is offline   Reply With Quote
Old 07-14-2012, 08:37 PM   #13
kingwood390bh's Avatar
On my 2010 390bh the outlet in the bunk area works because my son plays Xbox. I had hoped the outlets next to the front seats would work, but they don't. We usually run with the generator because it burns so little fuel.
kingwood390bh is offline   Reply With Quote
Old 08-13-2012, 06:31 PM   #14
Well the only one I found that works is the one under the TV. And with the slide in, we have to use an extention cord with the door cracked. I had hoped more were set up to utilize, especially the ones behind the seats, but no go. Bad design on BH's part.
heish1 is offline   Reply With Quote
Old 08-13-2012, 07:05 PM   #15
Berkshire 390QS
NO3putt's Avatar
Suggestion, with no shore power and generator off, turn on the inverter and walk around and try a night light in the outlets and either lable or mark the outlets that have power.
Skip
NO3putt is online now   Reply With Quote
Old 08-17-2012, 08:18 AM   #16
2011 Berkshire 390BH
We have a 2011 Berkshire 390BH. With the inverter turned on, the outlets in each bunk work as well as the two outlets above the 'dresser' in the bedroom (which means the bedroom TV works). In essence, all the 110 outlets in the wardrobe slide. The outlet in the compartment under the main TV works as well (so the main TV has power) which powers the electronics so people can watch DVDs in the bedroom. But then you have the issue of gaining access to the comparment while the slide is in. We tried one time simply removing the door for one of our longer trips but whatever we had in there would slide out when slowing down/stopping.
LiteEmUp is offline   Reply With Quote
Old 08-17-2012, 11:24 PM   #17
Without the generator running(powers all the outlets) the bunks and the entertainment area plugs work. I wish the plugs next to the driver and passenger worked, but they don't.
