Old 10-18-2015, 08:00 PM   #71
Tom you are just to funny.
Old 10-18-2015, 08:47 PM   #72
I don't think it's so damn funny!!!
BTW Phil, I'd say you have the same issue. What do you think? Are you going to pursue a solution?
Maybe we'll get lucky and find that we do NOT have a problem after all (I wish).
Boowho??
boowho is offline   Reply With Quote
Old 10-18-2015, 09:00 PM   #73
Boo I'm not sure what I'm going to do. My thinking at this point is that first I don't know if I have a issue. Now that is fine but I will stress like crazy worrying about what could happen. I plan to call and email FL with my concerns and request that they do an inspection of the hub. I really want a straight answer from them as to what all this 4 verses 5 bolt hubs are. I will do that and try to devise a way to easily inspect the hub. This might be a camera or something similar to be able to visually see the hub before a trip.
Other than that I guess I Monitor the hub and what FL has to say about it.
Any other suggestions? I'm open to any ideas.
Old 10-19-2015, 09:12 AM   #74
silver's Avatar
Hi Phil,
One interesting thing. When you look at Access Freightliner you cannot find the hub or fan clutch. Makes me wonder if they are specified by Cummins? Perhaps I just was not looking in the right place thou it is pretty easy to navigate Access Freightliner site. There are some people over on IRV2 talking about class action. Do not know if it is just talk or serious. More failures discussed over there.
silver is offline   Reply With Quote
Old 10-19-2015, 09:18 AM   #75
jmgllt's Avatar
Following
jmgllt is offline   Reply With Quote
Old 10-19-2015, 11:13 AM   #76
Yes, the biggest issue right now is knowing whether or not we actually have the flawed part. Even though we appear to have the four bolt arrangement (at least on the bolts visible in the pics), they may have beefed up those bolts and requirement of the 5 bolt hub is now moot.
Having said that, the DW has been researching this heavily. The hub is made by Horton (found a sticker on mine) and there are numerous recalls on Horton hubs by several companies that use them.
DW (ain't she a peach...... talk about a dog on a bone!!) even found this TSB number SF-388A-F by FL issuing a recall in 2007. Not sure if if applies to us but here is the link:
FREIGHTLINER XC 2007 Technical Service Bulletins
Boowho??
Old 10-19-2015, 11:55 AM   #77
One last item..... Here is the the diagram for the fan assembly specific to my VIN, from the Access Freightliner web site:
Silver, does this look like the diagram for your particular unit (that you mentioned a couple of messages back)??
Boowho??
Old 10-19-2015, 02:43 PM   #78
So Boo are you thinking the part #7 with the ( 4 ) bolts part # 6 are the culprits ? If that's the case sort of looks like it's under the pulley and you wouldn't be able to get an eyeball on it anyways. Maybe I'm off base.
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 10-19-2015, 03:34 PM   #79
accumack's Avatar
I confused now I thought I knew what to check. Keep us informed.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 10-19-2015, 04:16 PM   #80
silver's Avatar
I went back and found this under radiator rather than engine cooling where I had originally looked.
