Old 11-25-2015, 04:39 PM   #21
I love learning and hearing this stuff from MH owners! Good to hear these opinions for when we take that next step from the 5th wheel to a "bigger diesel." I do own the 1 ton Dodge/Cummins that pulls our unit and after 220,000 miles I've only had to replace the water pump (which is easy) and a few sensors! My point is, I would lean toward doing once-a-month runs. for all of those crazy sensors that are on diesel engines of EVERY size. By no means am I an expert, but when I've left my truck sitting for any number of reasons, the engine seemed a little off. The nature of any diesel is: They LOVE to run!! Just my 2 cents! Best wishes to y'all
RingoRoy15 is offline   Reply With Quote
Old 11-25-2015, 04:52 PM   #22
tnbendr's Avatar
The cruise control does have the higher idle feature by sliding over the resume button...but I don't think it bumps it up to 1100 rpm though
Ben & Michelle
2015 Berkshire 38A
2005 Jeep Wrangler toad
tnbendr is offline   Reply With Quote
Old 11-25-2015, 06:09 PM   #23
Kenny kustom's Avatar
I think mines around 1000.
I'll check tomorrow
2017 Dynamax Isata 4
Old 11-25-2015, 06:42 PM   #24
gasman94's Avatar
[QUOTE=RingoRoy15;1043462]I love learning and hearing this stuff from MH owners! Good to hear these opinions for when we take that next step from the 5th wheel to a "bigger diesel." I do own the 1 ton Dodge/Cummins that pulls our unit and after 220,000 miles I've only had to replace the water pump (which is easy) and a few sensors! My point is, I would lean toward doing once-a-month runs. for all of those crazy sensors that are on diesel engines of EVERY size. By no means am I an expert, but when I've left my truck sitting for any number of reasons, the engine seemed a little off. The nature of any diesel is: They LOVE to run!! Just my 2 cents! Best wishes to y'all[/QUOTE
Hey Ringo, we also love hearing stuff from other motorhome owners. That has taught many of us new things and saved us problems through others' experiences. Motorhome owner or not, all of us here are fans of the camping world and can learn a lot from each other. Good to hear all views...
Rich
gasman94 is offline   Reply With Quote
Old 11-25-2015, 07:40 PM   #25
[QUOTE=gasman94;1043555]
Rich
X2
Old 11-26-2015, 05:30 AM   #26
Originally Posted by I-RV View Post
Running the Cummins diesel at low idle (700 rpm) for lengthy periods is not recommended by Cummins. A fast-idle (1100rpm) is recommended.
I'm sure that many know and many do not know how to fast idle. While idling, with the cruise control on, you either depress the Set or slide the Resume switch. Phil, bail me out here.
Hank
You are spot on Hank.
Paul
Paulie Boy is offline   Reply With Quote
Old 11-26-2015, 05:38 PM   #27
High idle
Name:	ImageUploadedByForest River Forums1448581133.530156.jpg
Old 11-26-2015, 05:46 PM   #28
BamaBob's Avatar
I Can't WAIT until we get our Berk!
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 11-26-2015, 08:50 PM   #29
VinceU's Avatar
Per FL- fast idle press On then Set.
