Old 08-21-2015, 11:42 AM   #1
Engine Air Intake Louver - 2008 Berk 360QS
I've definitely been in one spot too long this summer. Birds have built a nest in the engine air intake louver. I need to remove the four screws holding the louver to the body of the Berk. I can't find a Torx to fit the screws even though I bought a new set. CR-V T20 is too large and CR-V T15 is too small. Where can I get the right tool for the job?
John
John & Rosemary
2008 Berkshire 360 QS
John & Rosemary
2008 Berk 360QS
MBE 900-330 w/Allison 3000
Jeep Liberty Toad
JohnKen is offline   Reply With Quote
Old 08-21-2015, 12:10 PM   #2
tmmar's Avatar
John,
I may look like torx but try a square bit. I had the same issue when I had my '08 and tried to find a torx bit to fit the screw and was told that it was a square bit.
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 08-21-2015, 01:57 PM   #3
Thanks, Tom. Square fits, but it's not snug enough to break them loose. Got one of four, but the others are just too tight. The square bit turns. Got to find something better before I end up stripping them completely...
John & Rosemary
2008 Berk 360QS
Jeep Liberty Toad
Old 08-23-2015, 07:05 PM   #4
You could crawl up underneath beside the tail pipe, disconnect the intake hose attached to the back side of that vent and clean it out that way. It's a tight squeeze but I am 6' and 195lbs and I can get in there fine. It's also a good spot to check on things in the engine compartment. Bring a flashlight.
James
James
2008 Berkshire 360QS-40
"If you can't fix it with a hammer, you have an electrical problem"
speedmerchant is offline   Reply With Quote
Old 08-24-2015, 12:16 AM   #5
jegstrup's Avatar
In a pinch, I've been able to use a small flat head screw driver to remove that kind of screw on my tig
2012 Forest River Berkshire 390FL
2013 Hyundai Veloster
jegstrup is offline   Reply With Quote
