Old 04-16-2014, 10:31 PM   #1
ernest917's Avatar
Engine Brake Question
My engine brake switch has two positions - the rocker switch can be pushed from top and bottom.... Almost like position 1 and position 2...
What's the difference??? Come on
Superchief - I know you know... Let's hear it....
ernest917 is online now   Reply With Quote
Old 04-16-2014, 10:59 PM   #2
adamsworld's Avatar
Usually high and low setting.
adamsworld is offline   Reply With Quote
Old 04-17-2014, 06:41 AM   #3
In the case if my 2011 340RB it is off and on.
Old 04-17-2014, 07:31 AM   #4
DanielJ's Avatar
My 2008 is off / on as well
2008 Berkshire 390TS
DanielJ is offline   Reply With Quote
Old 04-17-2014, 08:05 AM   #5
JTN8's Avatar
Same here on my 14, off or on. When in the city, hills or traffic I leave it on to save my brakes, but when I'm on the interstate I leave it off because if I take my foot off the gas or go down a hill it shifts down a gear and RPM'S go up and I lose momentum...
Old 04-17-2014, 08:53 AM   #6
ernest917's Avatar
My switch is a rocker switch - off is in middle position, then I can push it on by either pushing on the top or bottom... Not sure why it would require a rocker switch instead of a simple on/off switch...
Old 04-17-2014, 08:54 AM   #7
tmmar's Avatar
X2! Same here.
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 04-17-2014, 09:34 AM   #8
Do you have the Mercedes motor?
Old 04-17-2014, 09:40 AM   #9
ernest917's Avatar
Yes I do and it's great....
Old 04-17-2014, 09:43 AM   #10
puff's Avatar
In large tractors (18 wheeler) they have a 2 position switch for high and low engine brake or if you like to think of it differently partial jake and full. Not sure if your system is set up the same or maybe pre-wired for 2 with an option to upgrade..?
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
puff is offline   Reply With Quote
brakes
