Originally Posted by AREA51
psw757
Did you get the switch from FR?
Did you just remove the 4 screws from the switch bezel and pop out the switch?
GOOD LUCK
AREA51
Yes, ordered from FR parts, just need the switch and not the cover. I have a legacy which has same switches, had to remove 6 screws holding panel in dash where my cluster of switches is located. Then on back side of switch there are tabs holding it in place, push on and pop switch out and remove the wire leads then reinstall.
Very simple and took 5 minutes.
I've found the switch covers are kind of fragile and have had to replace a couple already.
Good luck
