Old 03-07-2015, 03:25 AM   #21
SKnight's Avatar
In my Cummins I've run Mobil Delvac 1 since the day i got it in 2003. Every engine in my yard has Mobil 1 in it, generators, lawnmower, four stroke weedeater, wife's van, daughter's car, literally everything.
I change it in my truck at 15,000 miles whether it needs it or not, usually every two years. When it was the daily driver it was 20,000, I had it analyzed a few times and all was well.
Old 03-07-2015, 08:38 AM   #22
Engineer of Crazy Train
ChooChooMan74's Avatar
I have the most unique diesel out here. In winter, I use Amsoil 5W40 Full SAPS and in summer, I use Amsoil 15W40 High TBN. The North American specs call for 0W40, but the local VM expert thinks the oil is the reason why we are having rocker wear issues in NA (I replaced mine shortly after I nought her).
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 03-07-2015, 08:53 AM   #23
No diesels, but I agree, Mobil 1 in everything, even use it in oil cans and if I change the oil (rarely), save the used for the chainsaw chain.
Old 03-07-2015, 04:50 PM   #24
gasman94's Avatar
Rotella T in the Berkshire. Once a year before I put her to bed in the winter. (I put less than 15k on the coach per year). This is what Cummins recommends, so I follow the program. I was told that the reason for such a lengthy period for oil changes was related to the volume of oil involved.
Rich
gasman94 is offline   Reply With Quote
Old 03-07-2015, 06:32 PM   #25
Originally Posted by beipers View Post
Then he proceeded to tell me that as long as the oil meets the API spec, they are compatible and the engine would meet its B20 design life.
Understand that.... But like everything else in life, people become VERY brand loyal.
I remember I dad always to me, "Billy, never buy a Ford; there no damn good". I was OK with that until in my early 20's when I asked dad if he'd ever owned a Ford.
He replied "Oh Hell, no..... Are you kidding??? they're no damn good!!!"
I've seen those attitudes displayed in trucks, computers, (Apple vs everything else), motor oil, etc, etc, etc.
Interesting, no?? Would make for a fine study in human nature!!!
Boowho??
boowho is offline   Reply With Quote
Old 03-07-2015, 06:39 PM   #26
Crusadernoob's Avatar
Originally Posted by boowho View Post
Getting ready to do my annual engine maintenance and am wondering what brand/type of diesel oil all you people use. Comments??
Boowho??
What engine?
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
Crusadernoob is offline   Reply With Quote
Old 03-08-2015, 09:26 PM   #27
Originally Posted by Crusadernoob View Post
What engine?
340 HP Cummins
Old 03-09-2015, 10:26 PM   #28
kingwood390bh's Avatar
On my 2010 I find the del vac most convenient because of the spout on the jug and the limited space where they located the oil fill. Mine is up at the top if the engine bay, too high for a normal funnel.
kingwood390bh is offline   Reply With Quote
Old 03-10-2015, 12:52 AM   #29
GreenImp's Avatar
Send a message via MSN to GreenImp
Oil is Oil...it is FAR more important to change it on time than which one you choose. Get whatever is convenient for you and meets the specs for your Cummins, then change it at proper intervals.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2021 Solitude 310GK w/FBP
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 03-10-2015, 04:42 AM   #30
gasman94's Avatar
Picked up a couple of these and am going to use for oil change filling and one for filling DEF http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Rich
Old 03-11-2015, 10:35 AM   #31
Pretty much agree (NOW).......
Boowho??
Old 03-11-2015, 10:56 AM   #32
R&J Silverback's Avatar
as you can see oil is a funny thing. I will say that the brand name isn't the big think, The BIG THING is change It as per the manufactures guidelines.
Ron & Jan and black dog(Bella)
2011 Ram 3500 crew cab 4x4, 6sp manual,342's 8ft.bed
2014 CC Silverback 29ik
R&J Silverback is offline   Reply With Quote
Old 03-11-2015, 11:21 PM   #33
Synthetic oil should not be used in the vehicle until you have about 30k miles on it.
Even at that time .... unless you put on a lot of miles each year ... synthetic is a waste of money.
The big advantage of synthetic is the fact that it takes longer to break down.
If you are the typical rv user that drives 6 to 10k per year... it makes more sence to change oil once a year before putting it into storage ... With regular oil
lefaivre is offline   Reply With Quote
Old 03-11-2015, 11:56 PM   #34
SKnight's Avatar
Synthetic has far more positives than the time it takes to break down. Higher shear strength, lower friction properties, thermal stability (Very important when flowing through a hot turbo.) are only some of the benefits.
Old 03-12-2015, 08:22 AM   #35
Don't know where you get the 30K figure or the other things you state. I was personally told by Smokey Yunick in 1978 to drain the oil & change the filter when I got 3000 miles on my new 78 chev pu and put Mobil1 in it. I took Smokey's advice then and have done the exact same thing on the 8 or 9 new vehicles I've owned since then with no problems. I have Mobil 1 in the engine, trans, and rear end in everything. Costs me about $30 for oil/change every 15k miles.
Old 03-12-2015, 09:18 AM   #36
Pixelbum1's Avatar
I agree with Mr Knight and "Coot" in responding to Lefaivre(no offense, OK?). BOTH in terms of science AND ecology, btw. The cost of any synth today is coming down and dino oil is going up so for the few bucks diff it MORE than makes sense to use synth! Try Walmart synth(tec) in your cars at least...very cost effective! I've seen severe stress tests on old engines using synth vs. dino oil until complete failure and the synth engines far outpaced the dino oil engines...that sez it all to me. Again, thank the Nazi's during the war for "having" to invent this kind of oil so that their tanks and trucks could survive the trek to Stalingrad across the Siberian tundra. Dino oil would have gooped up within the first 100 miles of that caper!
Anyway...yeah...no matter what...or oil...CHANGE the oil&filt...on schedule as per the manu's recco and ye all shall be fine! Don't forget the generator! -PB
PS: I change the oil&filt religiously around 2500 miles(if dino oil) on all my auto's. My
200,000 mile plus (dunno as the odometer quit long ago...) '95 Honda has the
cleanest looking cam and lifters as attested by two different techs...most recently
when I had the valve cover gasket changed...they were amazed! If synth oil is
used I wait till around 4000 miles dependent on driving conditions, of course. On
my Mercedes Blu Tec I will change oil & filter once a yr. before putting it to bed
around T'Giving. And oh...I have NEVER, EVER, had a smoking engine
or a "smoker" in my life(that's about 15+ vehicles, new and old!).
Other probs, yes, but NEVER...THAT! :]
Pixelbum1 is offline   Reply With Quote
Old 03-12-2015, 09:54 AM   #37
(Dry Huunday)
DreiHunde's Avatar
The wifes 2013 Toyota Camry rolled out of the factory with synthetic and a 10,000 mile interval.
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 03-12-2015, 10:10 AM   #38
Shhh! Don't tell anyone!
Old 03-12-2015, 10:16 AM   #39
Pixelbum1's Avatar
I just "connected" your login name with the avatar pic of your poochies! Cool beans! Ever live in Deutschland? Was stationed in "Zwie"brucken back in the 70's for 3 yrs("two" Bridges). ANYWAY, I digress...leave it to Toyota to do it right! Your comment underscores everything that's been said thus far! Good one! Those are happy & contented looking canines indeed! My best...PB
Old 03-12-2015, 10:17 AM   #40
(Dry Huunday)
DreiHunde's Avatar
Oops!!!
Beau & Sue
FurKid Express
