Old 01-26-2015, 07:33 PM   #21
I tried turning the key once and find out you can turn key to the left but not start it... Only Turing to the right will start... Seams simple buy I had to call a friend... And still hearing the story. Hope that helps or jets a giggle!
2014 400BH-60
jcowles3 is offline   Reply With Quote
Old 01-26-2015, 08:40 PM   #22
bubbles's Avatar
Originally Posted by gspencer4 View Post
My 2014 Berk 390BH-60 will both start and can be driven with slides out. I know because my house batteries were dead and my wardrobe slide was out and I had to drive it 5 miles to an RV service center. Everything worked. You should have no problem.
Greg Spencer
2014 Berkshire 390BH-60
If this ever happens again use the emergency start switch to bring the slides in. I believe the switch ties both circuits together for just such a purpose. If either battery (coach or chassis) is dead the switch will provide the 12 volts necessary for those circuits. Of course one of the batteries must be good. I think this is correct.
Old 01-31-2015, 01:34 PM   #23
My 08 will start with jacks down slides out but jacks will come up slides won't move with the engine running. Jim
jrlebaron is offline   Reply With Quote
