04-09-2019, 03:54 PM
Engine - turned off by its own for a couple of seconds
The other day while driving down Interstate with cruise set at 70 mph and probably going right at that desired speed the engine just 'turned off'! All dash gauges, tach and speedometer went towards zero. The in a matter of very few seconds, less than 5, the engine turned back on. No codes were set, no check engine light ever came on either. Then I drove home another 1,800 miles with not hic-cups! Anyone else ever have something like this?
Thanks,
2014 Berkshire 400QL; sometimes towing 2018 Silverado and other times
towing my 20' Aluma trailer with a vehicle on it.
04-09-2019, 04:18 PM
Yes, happened to me and several others. I don't believe anyone has figured out what cause of that yet.
Dan
2014 Berkshire 390RB-60
04-09-2019, 04:29 PM
Thanks,
You may want to check the internet and search for factory recalls on that model of Silverado.
Your year and model are not listed.
04-09-2019, 04:32 PM
Actually the profile says 2007 Silverado, but I believe she's having problems with her motor home.
Dan
04-09-2019, 04:42 PM
Just as confused as you
X2, the Berkshire is their motorhome and the Silverado is their toad.
Richard & Jill
04-09-2019, 05:07 PM
It was aliens
_________________________
Crusader 337QBH
2019 F350 6.7L DRW CC LB 4x4 Lariat
B&W Companion 20K for OEM pucks.
04-09-2019, 05:31 PM
I have also had this shutdown occur a few times to me. As the OP stated, no codes set and no check engine light. As secret squirrel stated- must be aliens!!(LOL!) Have not seen Freightliner or anyone else come up with a solution to this issue.
Tom and Margaret
2014 Berkshire 390bh-60
04-09-2019, 06:55 PM
A total electrical power loss is most likely caused by the chassis battery disconnect.
1- Check that all cables are firmly connected to the battery terminals and no corrosion present.
2- Check the "Negative" cable (usually black) cable are properly grounded, no corrosion, and firmly connected to the frame of the couch.
3-Follow the "Positive" cable (usually red) out of the battery into the master switch or disconnect relay or any device in line with that cable from the coach battery as that battery is the one to keep all alive.
I have read another thread here with similar issue and one of those devices were faulty.
I hope it helps some.
Sergio & Patricia
Legacy C38. 2018.
South Texas.
04-09-2019, 07:06 PM
Would't you be able to run the coach just off the alternate . once started the battery should be able to be disconnected and the alt keeps it going ? /i could see a problem with the ignition switch
04-09-2019, 07:37 PM
Apple Valley, CA
Engine stopped
3 years ago I had the same exact problem twice. Once was on the freeway, the second time was on the off-ramp. That one worried me a little bit. It hasn't happened since then. Keeping my fingers crossed must work.
04-09-2019, 09:11 PM
Originally Posted by SecretSquirrel
I'm pretty sure it wasn't aliens. I know where they are, but it could be aliens.
2020 S.O.B.
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Full Time in the Summer, soon
Part Time in the Winter
Days Camped, Not Enough
04-10-2019, 11:33 AM
Silly of me; missing something that obvious.
04-10-2019, 11:45 AM
It does say the Silverado is her tow vehicle, so maybe she's pulling the Berkshire witj it. Lol
Dan
04-10-2019, 12:23 PM
Read this if you haven't... The answer may be here in the BBC
https://groups.io/g/alfaseeya/topic/...0,2,0,18105187
2017 Puma 297RLSS
04-10-2019, 02:45 PM
Loss of power - intermittentantly
I had a Chevy 1 ton pickup that did this several times....and it was tough tracking it down.
The problem was in the main power 'feed'. Imagine a very heavy cable to the starter motor - and then from there - a smaller gauge cable that came up from the starter motor terminal and fed all the 12 V circuits. The terminal on that cable was loose enough to cause this problem.
Fixing - I hammered the terminal crimp a bit - then soldered it (using a propane torch.) I also ran alternate power lines to the main distribution bus.
I would suggest that you look at the larger power cables - and look for a loose terminal - (nut loose) - or a poor crimp. It will be early in the power distribution system.
04-10-2019, 03:01 PM
Engine Turn off by its self
I have a 2010 Berkshire that I bought used in 2013. I had the same issue with my coach. I took it to Freightliner in Gaffney and because it was a very intermittent problem they were not optimistic that would be able to diagnose it however when they were ready to move the coach out of the garage it shut down just like it did driving down the highway. Fortunately they were able to diagnose the problem as the ignition. I do not remember exactly what the issue was except the technician told me it had something to do with tumblers within the ignition. I have not had the issue again so I'm assuming they corrected the problem. I hope this help you and anyone else with this issue.
Plus all Canadian Provinces except Manitoba and Saskatchewan
Camping History: 2014 - 240 days. 2015 - 210 days.
2016 - 265 days. 2017 - 244 days. 2018 - 217. 2019 -196 and now full-timing
04-10-2019, 06:40 PM
This...I had this problem on a vehicle and the battery connections were loose. Tightened them up and no more issues for me.
04-10-2019, 10:09 PM
Dragonship Captain
While there are a number of causes that will make a vehicle go dead, power cables, ignition switches etc. there have been a number of FL cases where it was "something else" and what still hasn't been determined.
2020 RAM 3500 DRW Long Horn. In the hunt for a Palomino TC, formerly a 2017 Berkshire 38A: https://dragonship.blog/
04-11-2019, 10:10 AM
Get it fixed. Probably electrical black box problem. Losing power can be really dangerous at the wrong time. It can get you killed. I had a similar problem with an auto trans.
04-11-2019, 02:04 PM
Dragonship Captain
Did you copy the "still not determined" part?
