Old 11-03-2015, 08:19 PM   #51
2011 Berkshire 390BH
Superchief's Avatar
Bob, Never really compared any. Bought the one that Dealer at time of purchase recommended. A little costly, with a $100 deductible, but to date in 4 years they have paid for every repair recommended that was outside of manufacturers warranty, which amounts to at least 3 repairs (that I can quickly remember - new hydraulic pump, new bed slide motor, and recently new Transmission Control Module). The only issue I face is that this extended warranty was for 5 years and/or 75000 miles. I hit the 5 years next year and am at 50,000 miles. Guess I need to be looking at the XLT with "you all"!!! Enjoy, and let me know (us) what you think of it.. Craig
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 11-05-2015, 05:37 PM   #52
I-RV's Avatar
Yahoo! My engine now cranks! I had a new TCM (Transmission Control Module) installed under the Allison warranty {another Yahoo!}. Superchief (Craig) and I had the same problem. Replacing the TCM fixed his problem as well.
I suggest that everyone reading take head of what to do if the engine will not crank; which might happen to you out in the middle of nowhere.
I noticed the problem when I went through the sequence of starting; namely key off to on, wait for glow plug light to go off and then to start - which it would not do. I found that if I turned the key quickly from off to start, the engine would crank for like two seconds. Sometimes this would have to be repeated to get the engine to start.
Of course, there could be other reasons that the engine will not start, but I suggest that you remember this trick.
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 11-05-2015, 06:02 PM   #53
tmmar's Avatar
Hank,
Happy to hear your problem has been fixed and that it did't cost anything!! 2 home runs in my book!
Tom and Margaret
2014 Berkshire 390bh-60
Old 11-05-2015, 06:05 PM   #54
Hank thanks for the follow up. With two failing it's good to know as it will save lots of searching.
Old 11-05-2015, 06:56 PM   #55
Superchief's Avatar
Hank, Great news!!
For others who may have the same issue and are beyond the 3 year Freightliner Warranty, it is best to get in touch with Allison to get there 5 year warranty service (Hank correct me if this was not your case). From my experience, Freightliner will not "honor" the Allison Warranty and will not process it. Craig
Craig
Old 11-05-2015, 09:23 PM   #56
silver's Avatar
Are these both 2500 transmissions? Have we discovered another deficiency like the four bolt hub that know one knows about???
silver is offline   Reply With Quote
Old 11-05-2015, 09:50 PM   #57
Superchief's Avatar
Mine is a 2500, don't know about Hanks...
Craig
Old 11-06-2015, 07:49 AM   #58
I-RV's Avatar
Mine is a 2500 as well.
Hank
Old 11-06-2015, 08:13 AM   #59
silver's Avatar
I thought you both had 2500 Transmissions. Isn't the TCM made by ARENS or is that just the shift controller? In any event I think as I have been reading this thread and similar threads else where the problem is only on 2500 transmission chassis and I suspect the TCM is different from the 3000 transmission. I could be wrong.
Old 11-09-2015, 09:46 PM   #60
I-RV's Avatar
More the likely the TCU is different between the 2500MH and 3000MH. Mine which was replace on my 2500MH is item 2 in the attached BOM.
Hank
