Old 07-14-2016, 12:14 PM   #11
wm1964's Avatar
Our unit falls into the "I cant use the remote without the door open" box. It has been that way since new when it had all the stock AV equipment. I have since upgraded everything but the glass will not let the IR signal pass through it. I plan to replace the glass with something else, I just have not done it yet.
2012 360 FWS
wm1964 is offline   Reply With Quote
Old 07-14-2016, 02:17 PM   #12
nathantoensing's Avatar
Switch your receiver to a Genie with RF. I have 3 remotes; main, bedroom & outside. With RF there's never an issue 👍
--Nathan
2016 38a
--Nathan
2016 38a
nathantoensing is offline   Reply With Quote
Old 07-16-2016, 12:06 AM   #13
I switched to RF as soon as I got the coach and upgraded the components. I wanted to control it from bed in the back. Also, mine produces quite a bit of heat and I keep it open. I may swap the "glass" out with some speaker material to let it breath.
JJvike is offline   Reply With Quote
Old 07-16-2016, 08:02 AM   #14
Texas Realtor's Avatar
I have the same type of glass that also have to keep door open!! Not good but plan to switch glass as well
Texas Realtor is offline   Reply With Quote
Old 07-23-2016, 11:37 AM   #15
ron377ts's Avatar
Did you try fresh batteries in the remote. If batteries are low, signal will be weak.
Ron & Joanne
Bella The chihuahua
2014 Georgetown XL 377
2007 Jeep Liberty
ron377ts is offline   Reply With Quote
Old 07-23-2016, 03:54 PM   #16
dan-nickie's Avatar
Solve my problem with this
https://www.amazon.com/Next-Generati.../dp/B000C1Z0HA
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
entertainment
