Old 03-27-2016, 10:23 AM   #1
Equalizer leveling system issue
I have a 2015 Berkshire XL 40RB. The Equalizer system works ok in the auto level mode but when I press the All Retract button the legs come up about 6 inches then stop. A second push of the button then retracts them fully. Any thoughts?
dsalmon55 is offline   Reply With Quote
Old 03-27-2016, 11:32 AM   #2
dan-nickie's Avatar
Thoughts.
Are the slides closed?
Have you check the hydraulic fluid?
engine running or not?
Batteries fully charged?
I read a lot of post before I got mine 2 years ago. I have followed this procedure and it has always worked.
Retract slides. Start engine. Wait for air pressure to build and compressor kick off. Retract the jacks.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 03-27-2016, 11:37 AM   #3
Berkshire 390QS
NO3putt's Avatar
Use the same procedure as Dan. Have you cleaned your jack pistons lately? We use a little silicon spray and then wipe down with clean cloth.
Old 03-27-2016, 11:52 AM   #4
MotoxDad's Avatar
Dsalmon55-
Have the same issue with my unit, haven't been able to figure out what's causing it. I have followed all steps suggested by others, except cleaning jacks with silicon spray. Going to call equalizer this week to see if they have a solution.
John
2014 Berkshire 400BH
Motocross Dad
MotoxDad is offline   Reply With Quote
Old 03-28-2016, 07:38 AM   #5
15berkxl's Avatar
This is from FR "It has a bad valve on the pump we would direct them to call Equalizer 574-274-3437 Speak with Randy Bowling at ex 339"
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 03-28-2016, 12:12 PM   #6
Wow, I'm impressed that FR monitors this and offers guidance. Many thanks to them and all who contributed. Dave
Old 03-29-2016, 06:36 AM   #7
All of the input you've read is from fellow Berkshire owners, not FR.
Paul
2015 XL 40QL-60
2015 Jeep Wrangler Unltd. Sahara
Paulie Boy is offline   Reply With Quote
Old 03-29-2016, 06:43 AM   #8
15berkxl's Avatar
Paul
2015 XL 40QL-60
Paul not totally true the response I posted was cut and pasted from a response from FR. True I have not seen a response directly from FR but they do monitor the forum and are aware of postings.
Wayne
Wayne
equalizer, leveling
