Old 05-18-2014, 04:40 PM   #1
Equalizer Systems Info
If someone could look at the attached (annotated) PDF and tell me what the marked (in yellow) component's purpose is, I'd appreciated it.
Boowoh??
File Type: pdf EQ002 FRD Auto Level Operation Guide- General 4-2013_2.pdf (143.9 KB, 104 views)
boowho is offline   Reply With Quote
Old 05-18-2014, 07:51 PM   #2
2011 Berkshire 390BH
Superchief's Avatar
Boohoo, The only yellow I see on the attachment was for valve 4. Is that what you wanted? I am somewhat familiar with the hydraulic pump, having to manually retract my jacks using the manual method with a drill. If you can be more specific, maybe I can help. Craig
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 05-18-2014, 08:56 PM   #3
dan-nickie's Avatar
I believe he is talking about the diagram, not the text grid.
He has added a text box 'near' a part that comes out the side of the unit that looks something like a brake light switch (I know it's not) and I have no idea.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 05-18-2014, 09:09 PM   #4
Superchief's Avatar
For some reason, my IPad doesn't pick up any area that you are describing. I attached a picture of a pump similar to his. He is asking about one of the areas that the red arrows are point too? Click image for larger version
Name:	ImageUploadedByForest River Forums1400465330.912630.jpg
Craig
Old 05-18-2014, 09:17 PM   #5
No, it's not valve 4. They come in on the TOP of the manifold. The do-hickie I'm referring to is on the side, pretty much adjacent to valve 4.
On my rig, it's to the inside of the manifold (away from the door) and at the very back (toward the rear of the coach).
Maybe it's not zoomed in far enough for you??
Boowho??
Old 05-18-2014, 09:20 PM   #6
You are right, Dan..... Imagine that NONE of the text is there and it will be quite obvious what the yellow is marking, I believe.
Boowho??
Old 05-18-2014, 09:21 PM   #7
For some reason, my IPad doesn't pick up any area that you are describing. I attached a picture of a pump similar to his. He is asking about one of the areas that the red arrows are point too? Attachment 52726. Craig
SC, that is not the area.....
Boowho??
Old 05-18-2014, 09:27 PM   #8
Superchief's Avatar
Still can't see it. Try this: attached picture has 4 arrows, is any of them pointing at the item?
Name:	ImageUploadedByForest River Forums1400466420.189958.jpg
Craig
Old 05-18-2014, 09:28 PM   #9
dan-nickie's Avatar
Craig,
Yes, a diagram similar to that.
No, to your red arrows, as your diagram seems to be a totally different unit.
Dan
Old 05-18-2014, 09:28 PM   #10
dan-nickie's Avatar
Attachment 52730. Craig
NOw you got it. #3
Dan
equalizer
