Old 10-11-2015, 06:58 PM   #1
tnbendr's Avatar
Everything...and the kitchen sink
Does anyone else have problems with leaking and/or dripping kitchen faucets?
Mine has been fixed and then replaced, and now the new one doesn't leak but continues to drip for awhile after use.
Ben & Michelle
2015 Berkshire 38A
2005 Jeep Wrangler toad
tnbendr is offline   Reply With Quote
Old 10-11-2015, 07:07 PM   #2
Berkshire 390QS
NO3putt's Avatar
Ours started to leak and just replaced it with a niceonefrom lowes.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
Old 10-11-2015, 07:17 PM   #3
Campin Cajun's Avatar
I haven't had any problems with mine.
Sent from my iPad using Tapatalk
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 10-11-2015, 07:52 PM   #4
tnbendr's Avatar
Your probably happier with one of your choosing, but under warranty I shouldn't have to by anything like that.
Ben & Michelle
2015 Berkshire 38A
Old 10-11-2015, 08:02 PM   #5
We will have our 4 years this April. I will replace all the inside faucets this winter. They all work ok just kinda low end.
Old 10-12-2015, 01:04 PM   #6
The day I took delivery of my brand new 2016 Surveyor 32RLTS I came into the kitchen and noticed water all over the floor. I had to remove the rear wall under the sink to access the plumbing and found the spray hose faucet was not threaded properly and was leaking. Later something was still leaking and I found that another connection as well as the trap were leaking. Thankfully nothing major or damaged, but left me with a less than stellar view. Other than that, our first camper and first year we've only had to replace the igniter for the gas water heater, and moldings are pooping loose everywhere.
Unfortunately I'm at a permanent site with no truck 2 hours from the dealer. So I'm learning a lot on my own.
Good luck! Make sure to you pipe tape too!
Thanks! Mike and Jan.
2016 Forest River Surveyor 32RLTS
(Newbies: Our first camper. No truck. Permanent campsite in Pocono Mountains, PA.)
PoconoFun is offline   Reply With Quote
Old 10-12-2015, 01:13 PM   #7
We replaced with Moen in the Kitchen and Bath, (Buy once for a Lifetime)! Youroo!!
Old 10-12-2015, 01:26 PM   #8
This seems to be a pretty common problem in a lot of RVs.
When I've walked through dealer lots or camping shows I've noticed a lot of them will zip tie a plastic bag over them to catch the antifreeze that drips out.
Mine drips a little after I use it but it goes right into the sink so it's not a big deal.
Iwritecode is online now   Reply With Quote
Old 10-13-2015, 06:58 AM   #9
MilCop4523's Avatar
Thats why we now turn our water off when we are not at the seasonal spot - we had our outdoor shower come off on the back end inside under the bathroom sink just enough to let the water run.
took it all apart, found no thread tape used and it was on finger tight,
hair dryed as much as we could and then got a small space heater and left it on for the weekend.
Good thing we did because it also went down below freezing over night Saturday.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
