Old 10-20-2015, 06:46 PM   #11
Campin Cajun's Avatar
I don't know which is best as far as plugged or unplugged when running the gen, I unplug from shore when I run my gen.
The one thing I know for sure is you should run your gen with no load on it for at least 15 minutes to remove any moisture from it before adding a load. Once the load is added listen to the gen go from an idle to a higher RPM, it will switch back and forth while loads are applied and come off the gen. Let this go on for at least 10 cycles which is usually about an hour or so.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 10-20-2015, 07:53 PM   #12
15berkxl's Avatar
Originally Posted by KAS View Post
When I bought my MH in 2014 I was warned by the dealer to NEVER! run the generator while being plugged into shore power or it could fry the circuits. So why take the chance?
He also told me half an hour every 2 weeks is plenty to "exercise" the generator as compared to 1 hour per month (frequency is more important than duration). Makes sense.
I can't speak for your dealer but I can tell you without doubt the shore power and generator are wired into the transfer switch it is impossible to have both energized at the same time so nothing can get fried. The generator has priority.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 10-20-2015, 08:34 PM   #13
KAS
Wayne
I wonder what he was talking about then, any ideas? I plug the MH cord into the outlet inside the storage compartment when I want to run the system off the generator. Or I plug into shore power alone. Why do both anyway? Is there any other combination possible that would be harmful?
KAS is offline   Reply With Quote
Old 10-20-2015, 08:56 PM   #14
Do you have a transfer switch? Is your gas or diesel? I imagine different systems yield different advice. Important to make sure what system we are talking about before taking advice on your system. Your might not be separate and you could fry the circuits.
Old 10-20-2015, 09:00 PM   #15
Joe I may get beat up for this but when I did store my rig it went into storage in November and took it out in February. I did not run the gen at all. I asked several folks that are in the diesel business and manage a Cummins shop. He said it's not gout I hurt a thing to how several months with out running it. He also encouraged me to run it for 45 minutes at a min when I did run it after several months of storage.
Old 10-20-2015, 09:08 PM   #16
KAS
It's gas powered (Sunseeker 2250LE Chevy 4500 chassis). I don't see any switch anywhere in the compartment, just the socket attached to the wall next to a vented but sealed electrical box (hums when connected) and the cord with the plug on the end.
Old 10-20-2015, 09:12 PM   #17
KAS
Originally Posted by 5456Mich View Post
When you want to let the generator run each month for an hour or two does the shore line have to be unplugged or can you just start it ? Not sure if any harm will occur to the transfer switch.
One thing that's important: put a good fuel preservative I your gas tank, it keeps the generator from getting gummed up.
Old 10-20-2015, 09:15 PM   #18
We are talking about a diesel gen. Yes they also benefit from an additive.
Old 10-20-2015, 09:19 PM   #19
I would think that you have a transfer switch. I think you need one if you have a gen. Not sure. You might want to get specific info about your MH.
Old 10-20-2015, 09:21 PM   #20
KAS
Is that a manual or automatic switch?
generator
