Old 12-01-2015, 12:54 AM   #1
External Propane?
Could the propane accessory connection be used "backwards" to connect an external propane bottle?
Camping semi-long term, in cold weather, means using up propane!
chesterhull is offline   Reply With Quote
Old 12-01-2015, 01:20 AM   #2
dan-nickie's Avatar
I don't think so. Seems that would be on the wrong side of the regulator.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 12-01-2015, 05:59 AM   #3
2014 360 QL
po 185's Avatar
no don't hook up there, you need to install what camping world calls ---stay longer propane adapter kit..
2014 360 ql
po 185 is offline   Reply With Quote
Old 12-01-2015, 06:06 AM   #4
I don't see the harm in it provided that the larger tank you were temporarily connecting had a correct regulator.
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 12-01-2015, 06:17 AM   #5
Oaklevel's Avatar
The connections would need to be made up (Not available commercially) & I doubt any propane installer would do it. And a regulator would be needed.
I would not try it myself........
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 12-01-2015, 07:28 AM   #6
RSchleder's Avatar
Oaklevel,
Sweet Mustang! Pic's small but looks like a 65? I had 3 65's, one of each body style a few years ago.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 12-01-2015, 09:07 AM   #7
A32Deuce's Avatar
You can get an Extend -a-Stay kit and use a 20/30 lb. bottle. It ties into the line before your regulator for the coach. I installed one on mine for when we are in one place for longer than a week. Easy to throw empty bottle in car and refill. I just make sure I have 3/4 tank load in coach before we stop.
A32Deuce is online now   Reply With Quote
Old 12-01-2015, 12:25 PM   #8
accumack's Avatar
This is what I have. Extend-A-Stay Standard Propane Kit - $63.69
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 12-01-2015, 02:27 PM   #9
BamaBob's Avatar
Another Alternative from Camco. This setup also includes a 12' LP hose so you can hook up another gas appliance:
http://www.amazon.com/Camco-59123-Pr...B8AV2RQKFWNM75
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 12-30-2015, 12:21 PM   #10
Scokat's Avatar
extend a stay
did you all take the current fitting out and add the extend a stay, or add the extend a stay onto the original fitting.
2013 Berkshire 390RB DP/360--(Toad)2009 Trailblazer.
3rd generation Disabled Veteran, oldest son is 4th Generation Disabled Veteran...its a family tradition.
Scokat is offline   Reply With Quote
propane
